morsk
NY
2026 SR5
My sub lapsed a while ago but yes I had all of those options on my 26 SR5 and disabled all of the seat belt dings
Cranberry
Dan
Manitoba Canada
Thank you for sharing this thread!
thanks for the report. its weird since you do a lookup on the website for supported vehicles and it shows 9 entries on dings and warnings for the 4runner but they dont show up in the app when i use the carista odb adapter. but ifi use the same adapter and walk over to my 25 4runner platinum they all show up.
on the 26 4runner platinum only 2 options show up and not the other 7 for seat belts.
DeStreGa5
Andrew
This is what I got back from them regarding the seatbelt dings after submitting my report from the app.
2025 2026 4runner 6th gen Carista Options / Settings for 2025+ 4Runner 6th Gen (screenshots) 1790205161710-0d
thats bs, my 25 shows all 9 options in the app but the 26 only shows 2 options but the website shows 9 options for the 6th gen 4runner.
there was no hardware change between the 25 and 26 MY 4runners.
2025 2026 4runner 6th gen Carista Options / Settings for 2025+ 4Runner 6th Gen (screenshots) 1790206140522-2f
ok i sent some error reports via "report a problem", did one from my 2025 and 2026 4runner platinum's. see how that goes.
here is the export from carista on my 2025 4runner platinum
Code:
Chassis & Engine:
Active Noise Cancellation (ANC)
      ON / *OFF*
Engine Sound Enhancement (ESE)
      ON / *OFF*
Dings & Warnings:
Warn when doors opened with headlights on
      *ON* / OFF
Seat belt warning ding (driver)
      ENABLED / *DISABLED*
Seat belt warning ding (front passenger)
Seat belt warning ding (rear right passenger)
Seat belt warning ding (rear left passenger)
Seat belt warning ding (rear center passenger)
Ding when key is left in the car
      *ENABLED* / DISABLED
Driver Assist:
Rear Cross Traffic Alert (RCTA) system
Blind spot monitor
Heater & A/C:
Temperature dial calibration
      -2 °C (28.4 °F) / -1 °C (30.2 °F) / *NORMAL* / +1 °C (33.8 °F) / +2 °C (35.6 °F)
Instruments: Displays & Nav:
Instrument lights restoring sensitivity
      DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Display odometer after ignition is turned off for…
      *30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Microphone sensitivity
Speaker volume
Instruments: Heads-Up Display (HUD):
Image distortion in heads-up display (HUD)
      CONCAVE HIGH / CONCAVE MEDIUM / CONCAVE LOW / *DEFAULT* / CONVEX LOW / CONVEX MEDIUM / CONVEX HIGH
Lights: Automatic:
Auto headlights activation threshold
Turn headlights on when wipers operated continuously and headlights are switched on AUTO (req. auto headlights)
Lights: Exterior:
Daytime running lights
      *ON* / OFF
Lane-change turn signal auto-flasher count
      OFF / 3 FLASHES / 4 FLASHES / 5 FLASHES / 6 FLASHES / *7 FLASHES*
Turn signal click volume
      LOW / MEDIUM / *HIGH*
Coming-home lights duration
      OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Turn on marker lights when vehicle is unlocked via remote
Lights: Interior:
Turn on interior lights when you shut off engine
      *YES* / NO
Turn on interior lights when smart key in range
      *YES* / NO
Interior footlight (bright when doors open, dim when driving)
      *YES* / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
      *YES* / NO
Locking: Automatic:
Re-lock doors automatically if you unlock, but don't open a door within…
      30 SECONDS / *60 SECONDS* / 120 SECONDS
Locking: Beep & Blink:
Blink hazard lights when vehicle is locked via remote
Locking: Doors & Alarm:
Max number of consecutive lock/unlock cycles via touch sensor
      *UNLIMITED* / 2 TIMES
Warn (beep) when a window is still open when locking doors
      *YES* / NO
Warning when door is locked via button on door handle while ignition is left on
      *YES* / NO
Locking: Smart Key:
Touch-to-unlock-doors minimum duration
      *OFF* / SHORT / MEDIUM / LONG
After locking with smart key, don't allow re-opening within…
      *0.5 SECONDS* / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
      *FRONT AND BACK SEATS* / ANYWHERE IN VEHICLE
Mirrors:
Auto fold side-view mirrors (req. power folding mirrors)
      WITH IGNITION / WITH DOOR LOCKS / *DISABLED*
Parking Sensors:
Activate parking sensors in neutral (N)
      *YES* / NO
Front center parking sensor range
      SHORT / *LONG*
Front corner parking sensor range
      SHORT / *LONG*
Parking Support Brake (PKSB) vehicles from rear detection
Parking Support Brake (PKSB) rear detection sensitivity
      *STANDARD* / LOW
Seats & Steering Wheel:
Seat airflow level
      NORMAL / *SILENT (HIGH)* / SILENT (LOW)
Easy entry/exit
      *DISABLED* / RETRACT STEERING WHEEL FOR EASY ENTRY/EXIT / TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT / RETRACT AND TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT
Trunk:
Rear hatch walk away kick sensor
Trunk kick sensor sensitivity
      *LOW* / MEDIUM / HIGH
Trunk front seat switch button
      SHORT PRESS / *LONG PRESS*
Rear hatch open/close via remote
      *ON* / OFF
Rear hatch open/close with "one motion"
      *ON* / OFF
Rear hatch remote press
      SHORT PRESS / 2 SHORT PRESSES / *LONG PRESS*
Beep while opening/closing power rear hatch
      ON / *OFF*
Windows & Sunroof:
Open windows and sunroof via long-press on remote
      ON / *OFF*
Sunroof action when opening via holding down the driver side key for 1.5 seconds
      *SLIDE* / TILT
Sunroof action when opening via remote
      *SLIDE* / TILT
Beep when using windows comfort close with ignition off
Open windows and sunroof by turning and holding key in door lock
      ON / *OFF*
Close windows and sunroof by turning and holding key in door lock
      ON / *OFF*
Passenger window single-touch-open from driver's switch
Window (rear left) single-touch-open from driver's switch
Window (rear left) single-touch-close from driver's switch
Window (rear right) single-touch-open from driver's switch
Window (rear right) single-touch-close from driver's switch
Wiper voice control
Wipers & Washer:
Auto-enable rear wiper when front wipers on and reverse gear engaged
      SWITCH REAR WIPER FROM INTERMITTENT TO PERMANENT WIPING WHEN IN REVERSE / *TURN ON ONCE* / DISABLED
Enable rear window wiper when trunk is open
Other:
Panic function on remote
Obtained with Carista 10.0 for Android.
here is the export from my 2026 4runner platinum
Code:
Chassis & Engine:
      ON / *OFF*
      ON / *OFF*
Dings & Warnings:
      *ON* / OFF
Driver Assist:
Blind spot monitor
Heater & A/C:
Speaker volume
Lights: Automatic:
Lights: Exterior:
      *ON* / OFF
Lights: Interior:
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
Locking: Automatic:
      *YES* / NO
      *YES* / NO
Locking: Smart Key:
Mirrors:
Parking Sensors:
      *YES* / NO
      SHORT / *LONG*
      SHORT / *LONG*
      *STANDARD* / LOW
Seat airflow level
Easy entry/exit
      DISABLED / RETRACT STEERING WHEEL FOR EASY ENTRY/EXIT / *TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT* / RETRACT AND TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT
Trunk:
      ON / *OFF*
      *ON* / OFF
      ON / *OFF*
Windows & Sunroof:
      ON / *OFF*
      SLIDE / *TILT*
      *SLIDE* / TILT
      ON / *OFF*
      ON / *OFF*
Wiper voice control
Wipers & Washer:
Other:
ThatSickRIp
TSR
2026 4Runner SR5
Does Carista let you do more than 1 vehicle? I was wondering if I could do my 4R and the Old Ladys LC as well or do they make you get a separate subscription for each vehicle?
yes until your sub runs out.
i have both 25 and 26 4runner on mine, for the next 29 days. i never keep it longer than a month sub. once you set it, you never need to use it again.
i personally dont need a year sub for $60 vs $20 for a month and never need it again for the life of the vehicle.
since i did my 25, i have never needed to change any setting since then. so it was $20 once for 30 days and i was done using it after 10 days of testing. that was over 10 months ago.
only reason i have a sub now is for the 26 4runner, but not happy i dont have the same options as the 25 to change. so its mostly a waste of money at the moment unless something can be resolved with the reports i sent to carista to find out why options are missing on the 26 that are there for the 25.
to add fuel to the fire, even the toyota app is different between my 25 4R platinum and the 26 we have now.
here is my 2025 4R Platinum
2025 2026 4runner 6th gen Carista Options / Settings for 2025+ 4Runner 6th Gen (screenshots) 2025 Screenshot_20260926_204954_Toyota
and here is the 2026
2025 2026 4runner 6th gen Carista Options / Settings for 2025+ 4Runner 6th Gen (screenshots) 2026 Screenshot_20260926_204940_Toyota
so something is off between the two vehicles.
going to take it in and ask why there is less function on the 2026 vs my 2025
bossman
SF Bay Area
2026 Toyota 4Runner, 2020 Audi S6, 2023 Rivian R1S
I submitted a ticket to Carista. Will report back on what they say
im still waiting for a reply from an actual person instead of the AI bot they have.
