Build advice for my daily driver use case
Macaque
Washington
2026 TRD OR Hybrid
Hey all, new member and 6G owner here looking for some build advice from you knowledgeable folks.
I own a 2026 TRD Offroad Hybrid which I bought about a month ago. It will be my daily driver for commuting 40 miles round trip during the week. On the weekends I’ll be using it mostly for getting to remote spots for long range shooting up in the mountains and general offroad shenanigans. I planned on leaving it stock (except for a front skid plate) until the original tires needed replacement but my first trip to scout some spots revealed deficiencies. I’m looking for a sanity check and advice on part selection.
The ground clearance was pretty limited and I couldn’t make it up the trail (OnX 4 I believe) without wrecking my running boards. Now I have a C4 transfer case/transmission skid and C4 rock sliders on the way. Even with the protection I think I want to lift it about 2” up front and 1” in the rear. At the same time I’ll probably want to put tougher tires on there.
Goals:
  • Enough clearance so I don’t smash into obstacles
  • Improve ride comfort on poorly maintained forest service/fire/logging roads. A lot of washboard sections and potholes and the stock suspension was lacking. I like to go fast where it’s reasonably responsible to do so.
  • Not get stranded in the mountains because a rock goes through my sidewall
  • Retain the factory position of the spare tire
  • Preserve daily-driver considerations as much as possible. In order of prio gas mileage, comfort, road noise
Here’s my baseline plan right now it’s preliminary so if you have suggestions let em
Suspension:
  1. Fox 3.2 coilovers/shocks and to-be-determined rear springs - arguably overkill, but I will be spending quite a bit of time on rough logging roads at moderate speeds and these seem like the best there is for that use case
  2. UCAs of an undetermined type - this is an area where my knowledge is lacking. I’m thinking a tubular arm with a bushing and uniball is the way to go, but does that leave performance on the table compared to a Heim Joint? Unclear to me what the practical advantage is: does it let me tune behavior more, or just align easier to factory specs? Do billet arms have a practical strength advantage?
Other suspension questions:
  • Is there anything else I should upgrade while I’m down there and why? I don’t want to handicap the 3.2s by missing an obvious upgrade.
  • The 3.2 rears aren’t described as ”extended travel” so I‘m assuming I won’t get any more rear travel. Could I possibly be better off going with one of the 2.5 Fox/Icon/King kits that’s specified as extended travel and upgrading rear links etc? I plan on DIYing this so I’m hesitant to go that direction but I’m interested to hear what the pros/cons would be.
Wheels/tires:
I plan on keeping the stock size outer diameter. I may do these before the suspension. With reservoir shocks I think I’ll need to either add wheel spacers or go with lower offset wheels. I like the American Racing AR172 Baja or the Fifteen52 Analog HDs. I don’t want to be a basic bitch and go bronze even though it looks good. If I change wheels I’ll probably go with 17”. Only simple questions here:
  1. Before I do the lift, can I go all the way to 0 offset wheels without running into rubbing issues?
  2. Has anyone fit larger tires than stock in the factory spare location? It looks like there’s at least an inch of clearance between the spare and the hitch and exhaust, but I don’t want to do something dumb and start a fire
  3. Are E rated tires the only logical choice here? SLs would obviously be better for the road but I’m not sure how big the sidewall toughness difference is in practice.
Recovery
Unfortunately the C4 skid plate requires removing the front recovery hooks. Very disappointing and quite misleading that they don’t put this in the product description. It would have been incredibly easy to design the skid plate in such a way to bolt over or under a flat tow hook. This is an incredibly poor design decision. I’m pretty set against a steel bumper because I don’t want the weight and installation looks like a PITA.
Anyone have clever ideas for restoring a front recovery point without going to a steel bumper?
Conclusion
I have some significant and expensive upgrades planned. Does it seem like I’m approaching my goals in the right way? I’d love to hear your opinions. Thanks for making it this far.
2025 2026 4runner 6th gen Build advice for my daily driver use case IMG_2855
2025 2026 4runner 6th gen Build advice for my daily driver use case IMG_2846
bakutheleo
2025 4Runner i-Force Max
No comments on the rest (as I probably have less knowledge than you) but why not just use the OEM skid plate set? They just bolt on, no mods necessary. I did it on my ORP Hybrid myself with no problems. If you can be a little patient Toyota has sales on quite a bit--I paid about $700 for the front aluminum (steel would have been slightly less but I was trying to minimize weight), mid, and rear differential plates. There are plenty of other 3rd party options as well. Search this forum, they have been discussed quite a bit.
Macaque
Washington
2026 TRD OR Hybrid
Yeah I wanted steel, but I should have went with a different brand. Live and learn.
Macaque
Washington
2026 TRD OR Hybrid
Ordered the 3.2s, OME UCAs, and 17” Fifteen52 Turbomac HDs w/ E-rated 285/70r17 Duratracs.
Mods please delete if not allowed, but AI slop rendering of my vision for the final build is below - not sure what’s going on with the extra fog lights, but I do want the 2 round ambers in a hoop like that eventually.
I just couldn’t bring myself to do a bronze wheel build and wanted something a little unique. White wheels are probably a bad choice for the long term but what is life without risk. 2nd choice would probably be BBS TSMs in silver or AR172s in silver.
2025 2026 4runner 6th gen Build advice for my daily driver use case IMG_3129
Edit: As much as everyone hates AI, it is a pretty solid tool for planning stuff like this when you can’t draw well.
Other themes:
2025 2026 4runner 6th gen Build advice for my daily driver use case IMG_3120
2025 2026 4runner 6th gen Build advice for my daily driver use case IMG_3112
2025 2026 4runner 6th gen Build advice for my daily driver use case IMG_3039
2025 2026 4runner 6th gen Build advice for my daily driver use case IMG_2881
Macaque
Washington
2026 TRD OR Hybrid
Got the 3.2s installed. For anyone considering the Fox 3.2 Factory Race Series shocks for the 4Runner I would strongly advise against it.
The design of the reservoir mounting is absolutely horrendous to install. Instead of doing something basic like using something like a hose clamp, the decided to use T-nuts that slide into slots on the reservoir and then bolt to the mounting brackets. They are very, very difficult to get in due to location and the design of the nuts and brackets. There are a million different ways they could have made this easier, but it honestly seems like they didn’t even bother testing the install process before shipping the product. Getting the reservoirs mounted alone took >6 hours with 2 people, and I ended up using zip ties on 2 locations where the bolts just wouldn’t cooperate.
It’s absolutely unacceptable design on a shock that costs as much as these ones do. Do better Fox.
2025 2026 4runner 6th gen Build advice for my daily driver use case IMG_3260
FoRunna
Atlanta, GA
Man this is an absolute BUMMER to read because I was just considering ordering a set for my 4Runner.
That aside, how do you like the shock performance?
Macaque
Washington
2026 TRD OR Hybrid
Performance is great which makes it even more frustrating. I have them dialed up to 6 and the handling is awesome. Down at 1 they’re more comfortable than stock but seem to have a bit less body roll
fender flares, go with the matte black. if you get any pin striping, it would be a waste of money on the flares since they will just get ruined anyway besides the side of the vehicle. cost of painting them or getting them ordered painted just add roughly $350 to the cost of them (if you go with the rough country versions (https://www.roughcountry.com/product/configurable/toyota-sport-fender-flares-s-t12511c)
the odd ball colors on the renders just look whack/fuck in my opinion, along with the white wheels :ROFLMAO:
