Rellims
Sean
ORP - Underground
Ugh, maybe I just need to get my life right and order a set of these. That’s adult $$$ though. Are they noticeably better than the non premium OEMs? What’s the guess on a reasonable price to expect on the OEM premium take offs?
Maybe someone who got in a wreck may need the OEMs, other than that I don't think there will be a good market for them.
ryno
ryno
sw. mo
25 4 runner
they are way better , defiantly worth the $
ah4rsr5
Abraham
2025 4R SR5
Would like to see the picture of the beam outside compared to stock
Tamer1122
Sacramento, CA
Do they need any type of coding, and do they affect odometer readings ( BMW headlights need a ton of coding so as not to affect odometer readings)
ryno
ryno
sw. mo
25 4 runner
no, install and enjoy
Ty43mm
Terrence
LA
4Runner TRD-Off Road Premium
Where did you connect the yellow wire plug and which fuses did you tap the wires to? (That’s if you used the wire taps for activation sequence.)
2025 2026 4runner 6th gen Alpharex Nova Headlights installed, with lights ON photos IMG_4670
TMLifer
US
Looks great!
Does the Alpharex Nova headlights still allow the automatic adjusting light levels / brightness to still work? And do these headlights still allow for adjustment of the lighting aim with the dial on the dashboard?
Looks great!
Yes!
2025 2026 4runner 6th gen Alpharex Nova Headlights installed, with lights ON photos 6G4R_Fall Colors_04
TMLifer
US
Love the aggressive, Raptor eyes look of those Alpharex headlights!
How long did it take for you to do the upgrade? Any challenges or things to look out for when doing the installation? Having to remove and reinstall the front grille and bumper seems to be time-consuming and a pain.
Removing the bumper is easy, less than 10 mins work.
The longest part is running the wire for the DRL lights & unlock animation to the fuse box. Had to find the right fuse with constant power. Total, about 2 hours of work from start to finish. Lights are OEM fitment.
I had to adjust the height of the headlight down a bit since I have 33" tires on.
