Yes. I bought 5 tiresWhat did you guys end up doing with the spare tire? Did a 33” fit on the spare tire?
Did the 5th fit the wheel of the spare or did you also end up buying a new wheel?Yes. I bought 5 tires
It fit just fine. Dealer installed tires and spare. In fact it fit fine on my 5th gen.Did the 5th fit the wheel of the spare or did you also end up buying a new wheel?
The wheels with that 0 Offset
I also just put 285/70/r17 tires on my stock height and rim SR5. No rubbing at all and rides smooth. Let me know if anyone has questions.
Gorgeous! Do you get a lot of rub or other troubles with the 0 offset? I’m having a hard time finding the wheels I want in an offset any higher than 1mm. Ideally I’d like 18-25 but that’s been hard to find in the size I need.The wheels with that 0 Offset
that RIG appears to be LOOKING FOR A DAMN TRAIL it can't RUN...Nice af!!!!Quick picture.
2024 Tacoma trd off road wheels powder coated all black with Goodyear territory mt in 285/70/17. No rub…not even close. There is PLENTY of room in the wheel well!
not shown in the picture is the land cruiser front skid plate with the air dam removed.
fox 2.0 going on sometime after the holidays. Thanks to All Dogs Offroad!![]()
I’m doing the same as you, wild peak on stock rims. Did you do a 0 offset or what?I also just put 285/70/r17 tires on my stock height and rim SR5. No rubbing at all and rides smooth. Let me know if anyone has questions.
Does this account for the diameter change? I think the mpg is technically not correct on the SR5 oe setup because the tires are so small. The car actually needs 33’s to be correct.Maan you’re telling me! I ended up with AT3s too and so far has only been a 1 mpg hit. Was 19.6 or so stock, sitting at 18.6 rn. Need to give it a few more weeks for the numbers to settle I reckon.
I’m sure a lot of factors go into how this is calculated. I changed a few things, so can’t nail down how much each change cost in mpg. Tires are still AT3s, but I have the Tundra/Sequoia TRD Pro wheels. They’re a bit heavier than stock I think. I have an 2.5” lift up front and an 3” in the back. Also took the air dam off. I drive a bit spiritedly too. So with all that, I’m sitting at 17.3 or so.Does this account for the diameter change? I think the mpg is technically not correct on the SR5 oe setup because the tires are so small. The car actually needs 33’s to be correct.
