Pupperunner
John Doe
25' TrailHunter 4R
The +18 looks great! I went with a +15 on ours. Seems like +18 to +15 is just the right amount of poke
4Runner4Fun
Michigan
Looks great! Just curious, how much did your MPG drop when going to 285s? It looks like the KO3s are LT rating so 15-20lbs more per tire over stock? I have a Pro as well and am getting 19-20 mpg so far and don't want to drop below 18. I'm considering 285s for the future but the MPG hit is a consideration. Also, how is the ride? Noticeably firmer? Thanks.
TrdProGirl84
TrdProGirl84
2025 Toyota 4Runner TRD Pro
I haven’t honestly paid attention bc I don’t care. lol. But my guess is I’m getting like 15mpg. From 17-18. If you don’t wanna go below 18 you don’t need the LT E load tires. I’m definitely getting less than 18.
4running
TX
2020 4Runner SR5
Great looking setup @TrdProGirl84 !
How's the ride quality and steering feel with the upgraded tires?
Leaving it at stock height or adding a lift at some point?
Lucky09
Dane
Indianapolis
2013 Tundra
Not sure this helps, but my son has a Tacoma TRD Off-Road I-Force Max. He put on Nitto Recon Grappler 295/70r18 in Standard Load which are 52 lbs. His MPG is steady at 19 MPG now.
Also, Nitto (probably other brands too) make a 275/70r18 in Standard load that are about 46 lbs. Those are Terra Grappler G3s.
I'm not trying to sell you on Nitto, just wanted to point out there are options out there they might better suit your needs.
TrdProGirl84
TrdProGirl84
My Westcott Designs Preload Collar Lift gets here on Monday and it’ll be going on as soon as the shop I use has an appointment! I’m happy with the ridge quality and steering. :)
TrdProGirl84
TrdProGirl84
I haven’t paid attention. Will let you know once the lift goes on. But I know it’s less than 18. I have E load tires. Mx guess is 15mpg.
TrdProGirl84
TrdProGirl84
I wouldn’t get 285. If I were you I’d try the 275 and get the C load Rating the tire will be slightly lighter and such. But I still don’t think you’ll keep 18mpg!
Griffin27
So Cal
2025 4runner Limited
I have the 275/70/18 in Standard load Terra Grappler G3s, on my Limited. I absolutely love them, the ride is very smooth. Getting about 18 mpg combined, gas ver.
The problem is once you jump from 275 to 285 in an 18" it's impossible to find a tire that is not E or LT rated.
I have the Wescott Level kit installed which is also great, I noticed no change in the ride, but it looks so good.
2025 4runner 6th gen TRD Pro on 285/70/18 KO3 tires and KMC GRS +18 offset wheels, no lift IMG_3832-EDIT
Badkarma8541
James
st simons island
Thats the setup i have been running on my Pro since April. Lightweight tires and with the Volks and OTT hit 18 to 22 consistently.
TrdProGirl84
TrdProGirl84
I wasn’t even interested in any other options but E.
TrdProGirl84
TrdProGirl84
LT E is the same thing. The E is the Load Rating.
