NineOh4Runner
Gabe
Florida
Post your tent setup! I’d like to hear your thoughts on it
I’m looking to get one and keep going back and forth on a wedge style or a side fold out. Trying to see the pros and cons on each style.
Currently looking at these two.
Top Oak Galaxy Pro
Top Oak Vision
paleface
Vanaren
2025 Trail Hunter
My friend bought a Top Oak for his LC, the struts broken from one end and it slid and left a big scratch on the doors. The ladder hinges both broke off so it couldn’t grab onto the tent. Inspecting it and they were plastic with chrome wrapping to make it look like stainless steel I guess. He had left it open to air out for two days on top of the LC in his driveway in the summer. He called for a refund and all they did was gave him 20% additional off. Sent him a check but didn’t offer to send him replacement parts or repair options.
NineOh4Runner
NineOh4Runner
Gabe
Florida
Had a fear customer service might not be the greatest with Top Oak.
I’ve also been looking at FSR and 23 Zero but considering top oak as a budget option.
@gvan1998 which iKamper are you running?
gvan1998
MD
Im saving up for one. Dont have it yet
rocktheroad
Tampa
4Runner TRD ORP
I have the Top Oak galaxy 1.0 and I love it. The heating port has been a life saver, definitely recommend getting risers rather than using the mounting kit that comes with it.
Nice roof rack :)
Do you have a moonroof? I’m about to order the Top Oak Glaxy 2.0, but I’m a bit worried about how I’ll mount it. I saw what a mounting bracket looks like, and I’ll need to access the roof bar from the side, which is blocked by the side panels of the roof rack.
I was thinking of measuring the roof bar position, then removing two bars from the roof rack, mounting it on the roof top tent, and then lowering it and securing the roof bars back to the rack.
But that seems like a super precise and time-consuming job. How did you mount it?
odins_beer'd
Nice roof rack :)
thank you!
no moonroof unfortunately
the first time I mounted using their gear which tightens to the bottom of the extrusions. I took off the backplate of the rack and folded down the light bar protector so I could fit my hands in to tighten it. This was a pain in the butt and took about an hour.
I recently switched to Cali raised mounting gear that raises it about an inch (vibration harmonics were horrible on the their mounting gear). Then used the technique you refer to. Took out the extrusion bars and mounted them to the tent. I then cut up some 2x4 and placed a towel under them on my roof. Had a friend help me lift it and play with it enough to get the extrusions to line back up. I used an orange kicking tee and half of a barbell rod to help maneuver it. Used the back extrusion as a fulcrum with the barbell under the rear of the tent to hold it in place while my buddy screwed it in.
was it worth the hassle? Maybe maybe not. I just didn’t think it was worth 350 to have someone else do it.
best of luck!
4RunnerJay
usa
How do you like your SR5? Doing ok off road with a rooftop tent attached?
Do you miss anything that the higher trims could offer?
odins_beer'd
I like the sr5 a lot. Off-road it has been a beast. However once I added 400lbs of weight I started getting stuck more. I opted for
DOBINSONS DIFF DROP KIT - PRADO 250 / LAND CRUISER 250 - DD59-644
ICON 2025 Toyota 4Runner/2024-2025 Lexus GX550, Rear, Billet Adjustable Track Bar Kit 54202
ICON 2025 Toyota 4Runner, Front, Tubular Upper Control Arms W/ Delta Joint Pro 58452DJ
DOBINSONS REAR ADJUSTABLE SWAY BAR LINK - SE59-591
ARB OME 2025+ Toyota 4Runner MT64 Kit - 3in Front Lift / 2in Rear Lift 2134K (bolt on)
The OME kit should help with being weighed down. I also opted for a tune and sxth element Intake.
I really loved the front camera, locking diff, and leather seats would have been nice. Eventually plan on getting them.
I bought the sr5 full well knowing I was just going to upgrade it to my needs. That was my core justification for saving a few bucks on a higher trim if being completely honest.
4RunnerJay
usa
Thanks for the update. I guess I’ll have to start planning my mods.
NineOh4Runner
NineOh4Runner
Gabe
Florida
I’m betting the 2.0 is about the same size as that one. Are you able to keep your pillows and sleeping bag in there when closed and how’s the mattress comfort?
Were you saying you were having vibration issues on the mounting that came with the tent or the raised mounts from Cali raised?
odins_beer'd
So I just got it about two months ago and it’s super cold here at night. The first time there was condensation on the exposed metal so I bought felt to cover that (Amazon) and it’s been great.
Have not left pillows or blankets in just for the sake of mold. You could 100% leave blankets. I use the ikea bags. There is definitely some room with closing it. The mattress it comes with is okay. I’m 6’0 215 and my gf is 5’3 and petite.
Ended up you going to a mattress topper shop near me that does custom fittings to add a little topper and it’s been great.
there was vibration harmonics from the kit that came with the tent. The tent itself has rails under it and they lay across all the extrusions with the mounting gear fastening them together. So no matter how tight it is if you’re hitting trails or potholes you’re hearing sound.
Cali raised lifts the tent rails off the extrusion. Also ended up using stainless steel with anti seize over what was sent with Cali raised. Just for peace of mind.
Spektrum84
Kansas
4Runner TRD Pro
Installed a Sterling Adventure Wasatch Lite last weekend. First RTT. The ladder brackets attached to the tent rub on the roof rack rails and I've put some rubber dampener material between the surfaces for the time being until I can find a better and more permanent solution.
Tent quality appears fine. I don't have any other point of reference to compare it to. I bought it because it was one of if not the thinnest aluminum shelled, light weight, wedge tents available.
I'm 5'11" and will probably be sleeping at an angle in it because I sleep on my back.
If I had known they were going to release the Pro version of this tent so soon, I would have waited for the extra foot room. Oh well 🙄
2025 2026 4runner 6th gen Roof Top Tents. Post your RTT! PXL_20260328_195548239
