JGR
JGR
Gabe
This weekend, added Hood Struts and decided to paint the factory front tow hooks red.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1761
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1764
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1768
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1770
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1774
For now, the factory hooks in red add the subtle pop I was looking for.
Soloflight
Edward
SURREY, BC
Rav4
Did some things this weekend…
Swapped out the OEM meep meep and got the Land Cruiser Prado horns installed. Comparison with upgrade and original.
Also added a Zekzoop Insulation to the hood. Aside from thermal benefits, I noticed it improved the hood floppiness at highway speeds. Feels more stable with it on, less visual wobble.
After installing the insulation pad:
and finally got the air dam off! :)
Does the aftermarket hood insulation works?
JGR
JGR
Gabe
Definitely helps with the hood not flopping in highway speeds.
It reduces the engine noise, and from my observation makes the hood appear more sturdy.
I heard it helps protect the paint and the thermal aspect makes sense too.
Soloflight
Edward
SURREY, BC
Rav4
What brand did you use?
DannyvanDelft
Danny
Strongsville
2026 4Runner TRD ORP
How are you liking the tires? Are they white letters on one side, black on the other? I'm looking at these but I'm not crazy about the white letters showing.
Voltron
LV, NV
25 4Runner
It looks like you installed the struts in the wrong orientation.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension Screenshot_20251221_073046_Chrom
  • Like
Reactions: JGR
JGR
JGR
Gabe
Zekzoop from Amazon
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_2228
BFG KO3’s, they have white letter and black on the other side. All down to your preference.
I’m enjoying them, i recommend the C-rated if you’re not making the rig heavy and want better handling.
They def take a hit on MPG’s, but it makes the truck so different from stock.
Good catch, i must have gotten too excited. Literally stopped reading the instructions after the brackets. Better design would be to not let that install happen backwards! Thanks for letting me know, gonna correct that!
DannyvanDelft
Danny
Strongsville
Awesome, thank you!
Soloflight
Edward
SURREY, BC
Rav4
Hi everyone!
Been inspired by a lot on here and plan on adding pics along the journey of being a first time 4Runner owner.
Fresh from the dealership
Learned real quick that tint was needed. Went over to TX Tint & PPF in Austin, highly recommend them. Got XPEL XR+, 50 windshield, 15 on sides and 50 all around for uniform look (on top of factory shade).
And the itch hasn’t stopped… so I swapped the Yokohama X-CV’s and got some tires.
BF Goodrich KO3 265/70/17 on the stock SR5 wheels. Swapped the lug nuts to black.
Ended up with C-Rating, I tried the E-Rated for a week and it was too sluggish off the line. After one day of heavy rain, traction control went off causing the rears to swerve, which prompted me to swap.
Right now, I do have the air dam still on β€” but plan on deleting in future.
Wasn’t sure how I was going to like the white lettering on all black setup, but i’m digging the contrast at the moment.
Looking forward to driving this! Yeehaw!
Updated with new photos:
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension {filename}
Do you have any issues with ko3 balancing? Im thinking of just going with the trail terrain tires rather than the ko3s, what do you recommend?
JGR
JGR
Gabe
I personally haven't had issues so far, had the alignment done by toyota dealership.
KO2 if you want a good price, KO3 for all around balance on street and off road, i also like Toyo Open AT and Falken Wildpeak.
I will say that the KO3’s to me don’t make too much noise. Love the look and tread pattern in rain has been good so far (C-Rated).
I do recommend having an air compressor handy to play with the PSI settings at home rather than at a gas station. Right now i’m at 35 PSI instead of 33 PSI.
I haven’t had any issues with balancing on the KO3. And I’m on 285/70/R18 with a +18 offset. They were not road force balanced either.
Soloflight
Edward
SURREY, BC
Rav4
Thank you!
croome21
Cal
2025 Toyota 4runner SR5
What type of paint did you use?
