- First Name
- Gabe
- Joined
- Sep 1, 2025
- Threads
- 2
- Messages
- 39
- Reaction score
- 77
- Location
- Austin, TX
- Vehicle(s)
- 2025 4Runner SR5
Curious on this too, at what point does an OR outperform the SR5?
At the point that you high center the SR5 on something and wish you had that extra inch of ground clearance the OR has.Curious on this too, at what point does an OR outperform the SR5?
Haha, at least half of which comes from the slightly larger tireAt the point that you high center the SR5 on something and wish you had that extra inch of ground clearance the OR has.![]()
True, but still... I think the ground clearance (assuming stock tire size) is the only significant disadvantage unless you tackle some serious terrain .Haha, at least half of which comes from the slightly larger tire
*all* of it comes from a larger tire(*), a lift won't change the distance between the rear pumpkin and mother earth.Haha, at least half of which comes from the slightly larger tire
One has to wonder how the OR has 1” more clearance from a tire that is 0.5” larger in radius!*all* of it comes from a larger tire(*), a lift won't change the distance between the rear pumpkin and mother earth.
(*) unless you add portals
There is 1.05" difference in radius between the SR5 245/70R17 and OR 265/70R18 tires. That is the ground clearance difference as @shine stated.One has to wonder how the OR has 1” more clearance from a tire that is 0.5” larger in radius!
That's just plain wrong.I have no idea how Toyota measures ground clearance...
Ahhh I thought they were 31.5 tires. Now the numbers make senseThere is 1.05" difference in radius between the SR5 245/70R17 and OR 265/70R18 tires. That is the ground clearance difference as @shine stated.
