Prewiring Caliraised switches DIY non-hybrid ORP
porkbelly
Milky Way
4R6G
I spent a fair amount of time trying to find if someone tread this path before me and found similar installs/info, but nothing that satisfied this use case. So if there's another post that has another method, lmk.
The goal here is to populate the 5 blank switch spaces in my non-hybrid ORP with caliraised OEM style switches, where everything is prewired and the accessory just needs to be wired up to an awaiting terminal block. I took inspiration from the overland equipped aux power kit. I thought it was a bit expensive so I looked for alternatives.
In this design, the main breaker is 100 amps supporting a 12 position 100A fuse block w/ negative bus (for potential expansion), 5 relays, a hot and ground terminal block. The wiring should support the switch backlights coming on with the headlights if I can indeed find a fuse to piggyback from for those switch leads. If not, it can go to the relay along with the green wire. It only requires 9 total wires run through the firewall.
To add an accessory, pick a switch and just run your positive to the terminal block and negative to either the ground block, or negative bus on the main fuse block. Add the proper fuse for the circuit and you're done.
Rather than OE's AL plate bolted to the fuse box, I'm going with a piece of ABS that will cover the fuse box and extend into the empty space next to it to accommodate the terminal blocks and relays. The whole shebang shown in the diagram (not including the switches) comes in a quite a bit less than what the OE package costs ($230) for just the plate, breaker and fuse box. The Blue Seas 12 circuit fuse block, identical to what they're selling is 30 bucks, a breaker is $10, and 20' of 4 awg is $20.
2025 2026 4runner 6th gen Prewiring Caliraised switches DIY non-hybrid ORP wire diagram
horbit
DFW
I’m also wanting to populate the existing blank switches instead of using an auxbeam pad. I keep hearing the existing aux wiring isn’t fully installed on our models?
Mad Ghost
Wylie Texas
4Runner ORP and Avalon
there is no aux wiring in the ORP unless you have a Hybrid. super lame if you ask me. The hybrid people just have to plug in and its ready to go
Mad Ghost
Wylie Texas
I appreciate your efforts, I'm wanting to add ditch lights and possibly a light on roof rack
6thGen1419
Peter
New Mexico
Really? You're saying that my ORP iForce Max already has AUX wiring to the blanks, even though I didn't buy the AUX switches option?
6thGen1419
Peter
New Mexico
Correct.... it's ready to go
However, after reading the other threads on this topic, it appears the fuses and relays for the AUX circuits are not there and not wired to the fuse box on the ORP iForce Max without the AUX switches option. Is this correct?
Mad Ghost
Wylie Texas
The Hybrid should have the Aux switches and from what another use posted... they ran ditch lights to the connector in the engine bay and hit the switch inside the cabin and ta da let there be light sounded like a 10 min job. I have a non hybrid so I can not verify 100%
6thGen1419
Peter
New Mexico
I have an ORP iForce Max and I just checked. The relays and fuses for the AUX circuits are empty and not wired at the fuse box.
2025 2026 4runner 6th gen Prewiring Caliraised switches DIY non-hybrid ORP IMG_9744
2025 2026 4runner 6th gen Prewiring Caliraised switches DIY non-hybrid ORP IMG_9745
porkbelly
Milky Way
4R6G
I went through the fuse box with a multimeter, there are no circuits that are activated by the headlights on either driver or passenger side. I was able to find an unused (not fused) slot that did get power when the truck is on. ECU-IGP #3 on the drivers side. It takes a low profile mini style add-a-fuse.
So that will be the piggyback circuit for the switch backlights. Not ideal to be on at all times when the ignition is on, but better than splicing into the factory wiring, which is also one of the goals of the project.
Dead Horse
Oklahoma
Aux switches are an option on the hybrid ORP, and standard on the Pro and Trailhunter.
If you don't have the Aux switches, you do not have the supporting wiring/electrical system. Hell, the aux switches add a whole ass alternator to the thing, something none of the other hybrids have.
Boomer244
Ryan
SATX
2026 OFP Gas
porkbelly
Milky Way
4R6G
Similar but not the same. There is no non relayed circuit to run switch power. Also does not have the circuit breaker for the entire panel. Not sure how easy it would be to cleanly add accessories to it after running it without the dedicated terminal block. Can't speak to the form factor either. I know the height of what I installed clears underhood, just not by how much. I would probably call it a little cleaner of a solution to 70% of what's needed to replicate this.
Boomer244
Ryan
SATX
2026 OFP Gas
What is the non relayed circuit and/or circuit breaker for? I was comparing this fuse box the the cali wiring harness install videos i have seen, from what i coudl tell, i dont think those had a separate circuit or breaker. It seems like this is just six of them together in one box since the the lines seem to be running independently. Each relay has its own power going in, a switch leg and power out to the device. The grounding does look common for them all. I am basing this on the picture showing the underside of the wiring.
I would just run the wires from the switch to this and then from this to the lights. I did notice there isnt any grounding wires for the lights so i would just need to return them to a common ground somewhere or add a grounding bus bar. Its not very big so im not super concerned about fitment but i will double check that.
2025 2026 4runner 6th gen Prewiring Caliraised switches DIY non-hybrid ORP 1780060435610-hn
