Prewiring Caliraised switches DIY non-hybrid ORP
porkbelly
Milky Way
4R6G
The switch is what sends power to the relay to tell it to close the high power circuit so your accessory turns on, that power can't originate from the relay itself.
The circuit breaker isn't strictly needed, but protects the rest of the electrical system from the non oem stuff you're installing.
Boomer244
Ryan
SATX
2026 OFP Gas
Ah ok. I thought you just attached connector with all the red power lines directly to the battery.
porkbelly
Milky Way
4R6G
Like I said, it's not strictly necessary and you could run straight to the battery, but it's safer to have the fault protection. You could also run something like a midi or mega fuse instead of a breaker.
Mad Ghost
Justin
Wylie Texas
4Runner ORP and Avalon
That’s what I did went to the battery it’s got a fuse built in so I figured it was safe. Maybe other install methods could look a little cleaner but I only open the hood to do fluids and air filter anyway
