New 4Runner Dash Cam! ROVE R2-4K Dual PRO Dash Cam Front & Rear
Jeff
I picked up this new dash cam for my 2025 4Runner and have been very happy with it so far. It’s the Rove r2-4k. It records in 4k, has good quality video, and works great! I used an older version of this same one on my other 4Runner. That one is still running strong after 6 years. They are affordable too (way less than the one from Toyota).
Check it out here!: Rove Dash Cam
2025 2026 4runner 6th gen New 4Runner Dash Cam! ROVE R2-4K Dual PRO Dash Cam Front & Rear IMG_0132
xp0nex
2025 4Runner ORP
How did you run the wires to your rear camera?
2025 Big Red
Ron
4 Runner 2025
I went with the VIOFO 2 Pro. I love it. Some great off road footage. It super easy running the wire in the headliner. Mounting rear camera is different story. I removed one of the rear headliner tabs. Then took a piece of aluminum bar stock and formed to level where windshield wiper cleaned. However not to low that it gets in the way.
wheffner34
Will
Reading, PA
2025 4runner
Where did you tap into for your hardwire kit? I just got mine and im struggling to get the hardware kit correct for parking mode?
AdFour
Washington
There's 2 fuse boxes in the engine bay and one under the glove box area. The one directly in front of the of the driver (engine bay) has plenty of spots. Not sure about the glove box one, haven't looked inside.
I checked a couple of the empty fuses that do have power. But have a line across. Anyone know what they indicate?
2025 2026 4runner 6th gen New 4Runner Dash Cam! ROVE R2-4K Dual PRO Dash Cam Front & Rear Untitled1l2
SlateRiverPhotos
Jeff
I would run the wires through the headboard. It’s fairly easy to do with a plastic trim tool.
I realized that I linked the version with the rear camera. I have the one with the front facing camera only.
that looks ridiculous! I like the FitcamX mount and stealth look much better.
Yes, that looks super clean.
I didn’t hardwire mine. I plugged it into the cigarette lighter. You only need to hardwire it if you want it to be able to record when the car is not running.
