DangItsDen
Hayden
New shoes today. Very happy with how it came out.
Toyo AT3 285/70r17 Load C
Method 703 +35 mm offset
Peak Suspension 1.25" front level
2025 2026 4runner 6th gen Toyo AT3 285/70/17 Load C + Method 703 +35mm + Peak Suspension 1.25" front level lift Toyo AT3 285:70:17 Load C + Method 703 +35mm + Peak Suspension 1.25%22 front level lift 5
2025 2026 4runner 6th gen Toyo AT3 285/70/17 Load C + Method 703 +35mm + Peak Suspension 1.25" front level lift Toyo AT3 285:70:17 Load C + Method 703 +35mm + Peak Suspension 1.25%22 front level lift 4
2025 2026 4runner 6th gen Toyo AT3 285/70/17 Load C + Method 703 +35mm + Peak Suspension 1.25" front level lift Toyo AT3 285:70:17 Load C + Method 703 +35mm + Peak Suspension 1.25%22 front level lift 3
2025 2026 4runner 6th gen Toyo AT3 285/70/17 Load C + Method 703 +35mm + Peak Suspension 1.25" front level lift Toyo AT3 285:70:17 Load C + Method 703 +35mm + Peak Suspension 1.25%22 front level lift 2
2025 2026 4runner 6th gen Toyo AT3 285/70/17 Load C + Method 703 +35mm + Peak Suspension 1.25" front level lift IMG_1094
2025 2026 4runner 6th gen Toyo AT3 285/70/17 Load C + Method 703 +35mm + Peak Suspension 1.25" front level lift IMG_1091
2025 2026 4runner 6th gen Toyo AT3 285/70/17 Load C + Method 703 +35mm + Peak Suspension 1.25" front level lift Toyo AT3 285:70:17 Load C + Method 703 +35mm + Peak Suspension 1.25%22 front level lift 1
Scrappopatamus
Barry
Midway KY
Nice looking rig, and the 703s are a nice touch. You planning on lifting or a collar lift?
DangItsDen
DangItsDen
Hayden
Thanks. I already have the peak 1.25” level on the front. Gonna probably keep it this way
ExploreMore
US
25 4Runner TRD Pro
How does it drive. I have to imagine the on road ride suffered, but the off road will certainly improve.
DangItsDen
DangItsDen
Hayden
TL;DR - Not much of a change at all honestly. Very happy with it.
The change wasn't as harsh as I had anticipated. I went from SL load at3 in 265/70r18 which is like a 32.6" tire at 39 lbs each. New setup is like 32.8" at 54lbs each. With wheel weight diff, it was about an additional 12-14 lbs per corner. So far I have seen MAYBE a .5 mpg drop on this first tank of gas. Acceleration was affected a bit, but not as much as I thought it would. They are a touch louder on highway, but again, not bad at all. I have a manhole cover in my neighborhood that I always hit in a 45 mph zone that is kind of my test for bumps on road, and this set of tires even with the stiffer sidewall feels like it takes the bump smoother. Likely from the taller sidewall with the 17" wheel vs the 18"s.
I truly think this is the sweet spot for this truck. Load C will handle any off-road I plan to do, ~33" is plenty big but not too heavy for daily use. No rubbing with the 1.25" level and probably wouldnt even stock.
I have this same size tire in Ko3 load C on my 5th gen and that truck drives like a dog. This 6G massively outperforms it on the same size and load range for on-road driving.
jjbailey930
Potomac Falls, Va
Your truck looks great! I went with Method 709 HD with 0 offset and 265 / 17 Falken AT4s on my TRD Sport Premium. I am getting rubbing on inner part of front flaps lock to lock. Maybe will consider a slight lift/level at some point.
2025 2026 4runner 6th gen Toyo AT3 285/70/17 Load C + Method 703 +35mm + Peak Suspension 1.25" front level lift _DSC2304
Hypogeum
Stacey
Swanzey, NH
2025 4Runner TRD Offroad Premium
No rubbing at all that I've noticed. I have the pro/trailhunter mud guards on mine.
Interesting, I didn't know there were different mudguards for the Pro and Trailhunter. I am going to look into it, I hate not having them.
DangItsDen
DangItsDen
Hayden
They look the same but just wider to account for the wider flares and stance on the pro/TH
Hypogeum
Stacey
Swanzey, NH
I'll keep them in mind but to be quite honest, I daily drive my rig, I use beaters offroad so I just plan on the peak 1.25" and putting stock size "real" wildpeaks on. I just got rid of my Tundra that I blew thousands on, which is typical of me, and I am burnt out on putting suspension on rigs for no good reason other than to look cool. I have the black TRD wheels that came with it, may change those out at some point and the wider mudguards seem like a smart idea for that.
