kydo
Ky
san diego
2025 Toyota 4Runner Limited Iforce Max
I just purchased and installed the new Side Storage Box from Zekzoop. Installation was pretty easy, about 20-25 minutes and I’m pretty novice at car installation. Just 2 plates that bolt around the stock roof rails very securely and a bunch of super strong magnets on the bottom. I feared scratches from the magnets so I put a towel under during installation but I don't think it’s too necessary as the magnets are covered with a solid rubber that seems pretty scratch proof. The bolts on top along with the magnets on bottom creates a solid feel and secure fit.
The box does not open, I believe its designed that way to create a more tactical look while giving the magnets some side cover so its harder to get to them.
So far I like the look of it on the driver side. I haven't added any attachments to it and mileage hasn’t changed notably so far.
Pretty satisfied with the look especially with the price and ease of installation. Pictures show angles and video shows the top plates that you bolt around the rail. One picture shows it with the wing spoiler they also sell.
I tried to get every angle, hope this helps!
2025 2026 4runner 6th gen Zekzoop Rear Side Window Storage Box Installed 23638-6a377a61c89863ae96ed64ddfe06dab4
2025 2026 4runner 6th gen Zekzoop Rear Side Window Storage Box Installed 23639-f773570e8a622934248aae9877c19072
2025 2026 4runner 6th gen Zekzoop Rear Side Window Storage Box Installed 23640-6403dab94229f3247730a2f9f0c8d597
2025 2026 4runner 6th gen Zekzoop Rear Side Window Storage Box Installed IMG_1422
2025 2026 4runner 6th gen Zekzoop Rear Side Window Storage Box Installed IMG_1407
2025 2026 4runner 6th gen Zekzoop Rear Side Window Storage Box Installed IMG_1409
HVLA
Lexus
Interesting. Not a fan of magnets though. Dust WILL work under them and damage the paint. I would recommend some kind of vinyl sticker under them.
kgolive
Kevin
Huntington Beach
25 4Runner TRD ORP
I'm confused. It's a storage box but it doesn't open?
sliver
Guy
Atlanta GA
I'm thinking this could work with the ARB roofrack, with a bit of finagling.... Do you think so?
kydo
Ky
san diego
Correct it does not open. Its just the shape of a box instead of a panel
Zekzoop
New Jersey
I had to look this up too. They named it confusingly by calling it a "Storage Box". Its essentially a molle panel with some thickness to it.
Thanks for your correction! We will develop the name.
if you leave it attached all the time, your paint will be fubar where those rubber magnet feet touch
best to attach this when you need it and put it away when no in use...if you care about paint
rubber feet always grind micro dust into paint over time
