Diode Dynamics Hitch-mount LED lighting pod
it will since the canbus will detect a abnormal power draw. i think someone else posted maybe here that it did trigger the trailer function
RenoT4R
Reno
2025 4Runner , 2014 Raptor
I have one on my newer Raptor and I was getting weird issues with the C1R+Brake model and the towing light. Switched it to the standard C1 which is only a backup light and a tail light. That model didn't cause any issues.
Bernie
Bernie
2018 Mercedes AMG GTc
I kinda wanted it for the F1-like brake strobe, but I’m not sure it will work.
thanks for the heads up on the + brake option.
may forgo the brake option and just go with only the backup light
ToYoDaMan
Allan
Bay Area
I have the Reverse +Brake and so far no issues.
ToYoDaMan
Allan
Bay Area
Do you also have the tow package?
My window sticker shows this as being included on my ORP
Towing: Integrated towing receiver hitch and wiring harness with 4- and 7-pin connectors
do you have the TBC switches on the front dash ?
is probably the correct question to ask, the pigtail and the 4/7 pin connector has no bearing on the tbc control software built in
i mean my 2014 came with the oem pigtail and 4/7 connector but no brake controller.
ToYoDaMan
Allan
Bay Area
Got it! I would have to check. I'll get back to you on this.
ToYoDaMan
Allan
Bay Area
@Nodak, I don't have the tow tech package, therefore, I don't have the TBC switches on the front dash.
well that would explain the no error messages since you dont have the TBC installed. the TBC works by sensing a power draw from the 4/7 pin adapter thru the canbus.
either way, i ordered the brake light + backup light, i will see how it goes when it gets here.
thanks for the reply
