2025 4Runner - trim, mirror melting in the Harsh northern sun
Unhappy_owner
Jon
2025 TRD Off-Road Premium, 2019 SR5 Premium
My 3rd 4Runner. 2025 TRD Off-Road Premium. Very disappointed in Toyota!
Driver wheel well trim and side view mirror, and rear window trim melting. Parked in driveway in Massachusetts. Dealer and Toyota refuse to address.
2025 2026 4runner 6th gen 2025 4Runner - trim, mirror melting in the Harsh northern sun Image (4)
2025 2026 4runner 6th gen 2025 4Runner - trim, mirror melting in the Harsh northern sun Image (9)
2025 2026 4runner 6th gen 2025 4Runner - trim, mirror melting in the Harsh northern sun Image (8)
2025 2026 4runner 6th gen 2025 4Runner - trim, mirror melting in the Harsh northern sun Image (7)
2025 2026 4runner 6th gen 2025 4Runner - trim, mirror melting in the Harsh northern sun Image (3)
2025 2026 4runner 6th gen 2025 4Runner - trim, mirror melting in the Harsh northern sun Image (6)
2025 2026 4runner 6th gen 2025 4Runner - trim, mirror melting in the Harsh northern sun Image (5)
Mad Ghost
Wylie Texas
4Runner ORP and Avalon
Now that is bizare, I live in Texas so clearly alot hotter and my 4runner was in Death Valley this summer and looks perfect. The fender flares are weird, the mirror caps look like something in the enviornment could have gotten on them and same for the window trim. I say try another dealer and if none will help out those parts are cheap to replace if you needed to.. The trd pro ones go for $230 for the set
that looks like heat reflection off something.
you wouldnt have a very specific narrow band of melting if it was just general in the open melting.
glocke12
greg
PA
6th gen TRD Off Road Premium
Something isn't right here. How long have you had your vehicle ?
I live in eastern pa and I got my 4runner on August 7...Between than and now we've had week long periods of 100 dg/100% humidity days, and I park in direct sunlight ( no garage and I don't park under trees to avoid tree sap ). I think it take a lot more heat and sunlight to damage those parts than you or I will ever see.
that looks to me more like it reacted chemically with something. I am assuming you have washed the vehicle with something..what cleaners have you used and what have you used to bring out the blackness on those black trim pieces.
The fender flares also look like they had something applied to them that caused a reaction with the plastic.
As an FYI, a different dealer may be willing to help you so I'd warranty shop if it were me and not mention anything about prior experiences.
If that fails, I would just pay out of pocket for replacement parts and put it behind me.
Vincenzo
Southeast
That clearly looks like an extraordinary heat event. That is not normal wear from the elements. I’m gonna say, maybe, localized exposure to a heat source or light transmission. Light magnified off of a reflective surface
glocke12
greg
PA
it would require a lot of heat and light focused very intensely for that to happen. Not really buying that, but not saying it couldn't happen, but it would have to be very intensely focused sunlight reflected for a long period of time for that to happen.
OP's driveway also looks like it is North-South facing so doesn't get direct sunlight all day long so I doubt it happened there.
Imp
SE Mass/RI & SC
2025 4Runner SP
This is 100% Sun reflection off low-e glass from a building/house. Either yours, neighbor, or work/street.
I know this because I had it happen to a Subaru I used to own. Sun reflected off my south facing windows onto my driveway.
If your house, you need a (bug) screen over the windows to help diffuse (what I did), or a film that can go over the glass. If neighbor/work... park somewhere else.
glocke12
greg
PA
I never would have guessed. I am going to have to find another parking spot where I work because I park near a building that reflects like that...
Badkarma8541
James
st simons island
Wow! I initially thought chemical but heat reflection makes sense. Park the car figured out exactly what it was reflected off of and go hit the building up to pay for repairs..
Imp
SE Mass/RI & SC
2025 4Runner SP
Yep. There are many cases where the business owners have paid for the repairs, and the town/city should be notified. However, you need to document time of day and which windows.
In my case, it was my windows on my house. If your house and parking position near absolutely cannot reflect the sun onto your 4R, then you need the above. And, don't park there. ;)
djw4run
Dick
Binghamton, NY
5th gen 4Runner 2025 RAV
There are cases of melting trim, side view mirrors etc on the 5th gen Toyota RAV forum which is what my wife drives. It is not pervasive or widespread but is affecting some owners mostly in hot areas of the country. I know that for a few owners, Toyota initially replaced those trim pieces but refused to replace them when the same damage occurred a second time.
Dog4Runner
Northern Virginia
2025 Off Road Premium Hybrid
100% this is the truth. I've had the same thing happen with a FORD. Direct sun reflection mixed with radiant heat source can damage this soft parts.
solar convergence
all makes all models complaints in every forum
back in the day plastics were a lot more robust
nowadays, you really need to consider where you
long-term park and watch for concentrated reflections
and avoid those areas
ifunlisted
AZ
This should still be on Toyota and other vehicle manufacturers. Construction companies can't account for every angle the sun will reflect off of every window, radiant barrier, and reflect surface of the building.... or how those angles will change throughout the year... or where cars might be parked in relation to those moving reflections. And car owners should not have to do a survey of potential hotspots every time they park. The car manufacturers should just use higher-grade plastic (or maybe less plastic in general but that's a tall ask).
