First Timer looking for off-road gear advice
ColoradoRoz
Roz
Parker, CO
2025 trd orp 4runner
Hi all! We picked up our TRD ORP a couple of weeks ago. In the lead up I've read and watched a lot of info on off-roading, and while I've learned a lot I'm not quite ready to take the car down to the shop to throw a ton of mods on it simply because I don't know what I'll want yet.
That said if I want to go dip my toes in the water (say to a trail rated up to 3, 4 tops) what would be the minimum gear I should be bringing? Ie: do I need a deflator and compressor on a 3? Recovery gear?
I'm trying to baseline so that I can get a feel for what mods I may want to get down the road.
Thanks all!
fur_runner
Aaron
25 ORPH
The easy answer is don't buy anything at all, go with ppl who already have gear and understand where you're coming from
MAYBE you need a winch but MAYBE you'll be uncomfortable taking a $60k truck into situations it may not come back from. You shouldn't worry about airing down non-LT rated tires, and if you're always gonna go alone you don't really need to worry about recovery gear.
If you really really don't want to find experienced ppl to go with, I would say you really only need two things:
1. Maxtrax will get you out of most things
2.. A satellite phone will get ppl to where you are when the Maxtrax don't work
Everything else - tires, winches, lifts, recovery gear - just get you further and further into trouble until you have ALL the gear and more experience.
Your truck has the tools on board to replace a tire, but not patch or repair a tire. I would consider that, independently of the off-road angle
ColoradoRoz
Roz
Parker, CO
Awesome - thanks for this. Finding some folks to go with was among the recommendations I read about, so I'll probably put more effort there. It'll delay gratification but probably the smart thing to do.
fur_runner
Aaron
25 ORPH
On a personal level, this ISN'T advice I followed, and I have a garage full of giant ropes and shit I'll never use. The truck is very capable out of the box, and the easiest thing that will increase it's capability is having another truck with you out on the trail
But you know what, it was rude of me to shut it down with the first reply. I need to remember that a lot of the fun of hobbies is the journey, even if it isn't realistic. Here is what my plan was:
Tier 1: Foundation & Core Recovery Tools
  1. All-Terrain Tires (Load C or E) - Most important for safety, grip, and durability. - Recommended: Falken Wildpeak AT3W, Toyo AT3, BFG KO3.
  2. Tire Pressure System
    1. Portable air compressor - Viair 520PP
    2. Tire deflator - ARB manual. If you get a tool that removes the cores, also carry a large number of spare cores
  3. Traction Boards - Maxtrax, ActionTrax, or GoTreads. - Solve most stuck scenarios without power tools.
  4. Tire Repair Kit + Full-Size Spare -
    1. Puncture repair, plug kit
    2. Offroad jack - bottle jack or floor jack that works in the dirt. I went with the 3tn Badlands, and use it when I'm working on the truck at home too
    3. Ratchet strap to help get the bead reseated
    4. Breaker bar with lug socket ready to go
  5. Kinetic Recovery Rope + Soft Shackles - Smooth, safe recovery with a second vehicle
    1. 3x 3/8" Factor55 soft shackles
    2. 7/8x30' Factor55 kinetic rope
    3. 7/8x10' Factor55 kinetic bridle
    4. Factor55 pro rear recovery point
  6. Portable GMRS walkie talkie
Tier 2: Protection, Comfort & Confidence
  1. Tree Saver Strap + Snatch Block
    1. If you're going to go right to this step on day one, you can use your tree strap as a bridle, but I would get both
    2. Get the Factor55 rope specific pulley
  2. Come-Along or Manual Winch - Slower but reliable solo recovery.
    1. Wyeth-Scott makes a 3tn rope specific come along, which won't need special mounting on the truck (so it works in the front AND back)
  3. Skid Plates - Engine, transmission, and transfer case protection.
  4. Recovery Gear Mounting
    1. Keep in mind that everything listed above is gonna be a nightmare in an accident (the rope puller is like 40lbs) so you need to plan a way to safely store it all
Tier 3: Overland-Ready Upgrades
  1. Suspension (2–2.5” Lift) - Notice how a collar lift wasn't on the list yet?
    1. Dobinsons Monotube or OME MT for clearance and ride.
    2. If you don't have SDM, have a dedicated set of tools to take off the endlinks-to-control-arm bolts, and the four bolts to hold the bushing brackets, and just throw the whole bar in the back of the truck when you're offroad
  2. Navigation & Communication
    1. Gaia GPS / OnX Offroad
    2. Onboard 20w+ GMRS radio
    3. Garmin inReach/sat phone - I have the SpotX personally
  3. Rear Cargo Setup - Drawer systems, MOLLE, fridge slide for gear access.
Tier 4: Extras & Expansion
  1. Roof Rack or Modular Storage - For light gear, not heavy items.
  2. Lighting - Ditch lights, scene lights for night use.
  3. Onboard Water + Filtration - Rotopax, jerry cans, Sawyer Squeeze.
This was the road I went down. I got most of the Teir 2 stuff before I realized that I didn't want to beat my truck up, and that my entire trunk was filled with ropes I never used. I hit the off-ramp on that plan when I realized what I liked was camping, and I left ALL that gear at home except the air compressor and the tire repair kit, and got fridges and solar and the stuff that improved my quality of life.
Again, sorry to shut it down, its fun to play even if it doesn't make sense, and everyone does it different. I hope you just go out there and have a great time with your truck!
Rellims
Sean
ORP - Underground
Wouldn't recommend starting out when there can be snow on the trail as that increases the likelihood that recovery gear will be needed.
I've heard good things about On Trail Training but have not personally taken a course.
If schedules align, I'll go with you on some starter trails like Sugarloaf or Switzerland. Won't need recovery gear there.
ColoradoRoz
Roz
Parker, CO
Dude, that Training link is huge! Thank you!
And thanks for the offer to go out. I will reach out at some point - as you suggested re: weather I think I'm mentally prepared to wait till spring.
odins_beer'd
This! Highly recommend getting out and seeing what you genuinely need. Personally I put armor in tier 1 because I destroyed the flimsy little rain shield and bent up my predator side steps.
  1. ...
    1. If you don't have SDM, have a dedicated set of tools to take off the endlinks-to-control-arm bolts, and the four bolts to hold the bushing brackets, and just throwthe whole bar in the back of the truck when you're offroad
fur_runner's entry above is one of the all time great posts on this forum in terms of helping a noob off-roader (me) to get things going. This weekend I traversed one of the more challenging trails (Pott's Mtn Jeep Trail in VA) - with most but not all of the things on the list.
But I came here to make an observation about sway bar disconnect without the SDM.
I was able - with a LOT of effort - to disconnect the sway bar links on my TRD OR. It took a 9" piece of pipe on the end of my large craftsman 1/2" socket wrench to finally break those big bolts free. The 3/8" wrench in the photo did NOT do the trick. (Torquing them back to 159ft-# takes some effort too.)
I considered completely removing the sway bar but that would have required removing the skid plate (not too tough) and completely removing the bushing brackets that connect the sway bar to the frame. I decided to test things without removing the bar and even at full up and down articulation the disconnected sway bar does not seem to get in the way of anything (and it does not rotate easily). The links also seem to not make contact with any other parts. So I risked it and made it through a black trail without damage - at least none to these parts. Posting here in case anyone knows that I should never do that again because I just got lucky.
Reinstallation (done twice) was easy on one side - link bolt lined right up with sway bar hole - but on the other side required levering the sway bar up to get the hole to line up.
Its an extra 10 minutes or so before and after the trail (while airing down/up). I've read about this being possible but wanted to post my experience and see if anyone else has done this.
2025 2026 4runner 6th gen First Timer looking for off-road gear advice 20260417_104418
2025 2026 4runner 6th gen First Timer looking for off-road gear advice 20260417_123958
Please do not hesitate to tell me what I did was dumb and why I shouldn't do it again.
Thanks!
fur_runner
Aaron
25 ORPH
If you're gonna disconnect the link, remove it entirely. I'd recommend removing it from the lower control arm (it's just easier to get to, and you don't need an Allen wrench to hold it still) At the least zip tie it down - if you remove it from the bar side, zip tie it down using the hole in the lower control arm. If you remove it from the control arm side, zip tie it to the sway bar.
