Sherpa or Westcott Lo-Pro roof rack??
DannoSchmanno
Danno
2025 4Runner TRD Pro
Here's a closer look at the Sherpa Capitol Rack on my TRD ORP iForce MAX. I debated between the Capitol and the Westcott Lo Pro but ended up going with the Sherpa, and I'm glad I did.
It doesn't have that much of a higher profile, but has enough clearance to allow for easy installs of the RTT, awning and other accessories. I can also confirm that it does not interfere with the sunroof/moonroof.
I installed the Sherpa last night, and the blue and red tape is marking the crossbars that will serve as attachment points for my FSR Aspen V2 RTT and a Kammok Crosswing awning. Coming soon!
PS: A quick note about the Kammok Crosswing. They recently announced a price increase that will go into effect starting June 16th, but they're honoring the current pricing until then, so if you're thinking about getting one, now's the time!
went with the capitol from sherpa, since i’ve never installed a rack (let alone one from sherpa) can someone who has installed the same sherpa take some photos of what the rubber stoppers and the bolts look like on theirs? wanting to see how much, if any, the rubber block should be squished down from tightening the bolts (same for the bonded washers) wanting to make sure they were not over tightening but also not under tightening and having a visual reference from others who have finished theirs would be helpful! thank you!
vready
Vince
Hood River, OR
@DannoSchmanno here's what mine looks like in the back. No easy access to take pictures of the front mounting hardware. You can see that the bonded washers are slightly compressed and bulging, but that's about it.
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_0748
DannoSchmanno
Danno
@vready thanks for sharing this, this is helpful!
i’ve attached a few photos from the back, both drivers side and passenger and i know angles can obscure things but it looks like our rubber block (and the metal rack support arms) is higher, and less compressed?, than yours are?
took a bunch of different angles trying to give a good perspective so you can give me your take. definitely want to make sure it’s secure and watertight. thank you again for your help, i really appreciate it!
passenger side back
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_7272
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_7276
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_7280
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_7279
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_7281
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_7282
driver side back
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_7274
2025 2026 4runner 6th gen Sherpa or Westcott Lo-Pro roof rack?? IMG_7275
M&M
I apologize, I know this is an old thread, but I'm trying to educate myself before buying my roof rack. Those rubber blocks, how much compression can they take? I live in Texas, and the heat here is brutal. I'm concerned that, over time, the rubber would crack since it's exposed to the elements, and the mount would sink in and damage the roof, or the screws would come loose due to the compression from everyday driving. Am I nuts?
vready
Vince
Hood River, OR
Hi M&M,
I really don't think you need to worry too much. The rubber feet sit behind the aluminum side rail, so they are shielded from direct sunlight and potential UV damage. I'm sure they're rugged enough to withstand high ambient temperatures within the ranges you'd experience. Hope that helps!
spyder40
Indiana
2021 4Runner ORP
Mine have sat out year round with no issues. Wouldn't be concerned on Sherpa
  • Like
Reactions: M&M
utah.greene91
Marc
Utah - SoCal
2025 OR
Not at all. I had the same concern as you since I'm out in the desert all the time. From what I am hearing, no one's had any issues with the rubbet feet/seals. I spoke with Corgrit, and they said they'd send replacement seals if they ever fail or break down.
https://www.corgrit.com/sherpa-equi...iring-for-6th-gen-4runner-2025-present-144844
