Rear Door Window Seal - Looks like its incorrectly fitted both sides
Has anyone noticed or can you take a look at the top of the black rubber windows seal. It's on the rear doors, both matching and in the same place. It's the top horizontal seal, closest to the front doors. It does not overlap and dips down for about 4 inches. See attached picture.
2025 2026 4runner 6th gen Rear Door Window Seal - Looks like its incorrectly fitted both sides Window Seal
Hacksaw
az
2025 4runner TRD-ORP
Yours is slightly more exaggerated than on mine but yes, similar on mine. If you take your thumbnail and slide it down from the painted metal above, down to the weatherstrip interface, the weatherstrip is slightly higher than the painted metal to the right of that 4" section, and the weatherstrip is either flush with or slightly lower than the painted metal within this 4" segment.
So we can assume normal? Looks like crap now that I have noticed it :) I need to stop washing the car as I keep noticing new stuff....
72and10bulls
Derick
New Mexico
2024 Toyota 4Runner TRD Offroad Premium (Underground) 2019 Toyota Tacoma TRD
For real just looked at ours in the garage seems a little off but will double check it in the sun light.
Hacksaw
az
There must be a reason for it. I didn't roll the window down and check whether there's a "bump" in the underlying metal that the weatherstrip fits into (e.g. a spot weld or overlapping metal joint), compared to the parts to the right. Or maybe the top edge of the window glass itself is not perfectly horizontal and is slightly higher on the left and compresses the weatherstrip more on the left end when rolled all the way up.
Did you happen to roll the window down and jiggle or pull out and re-insert the weatherstrip to see if you can make it all uniform, if not for the window compressing it?
I did roll the windows down and made a small effort to roll out some of the edge but I was not successful. I may try again this weekend.
Kennyg
Ken
Albuquerque, NM
2025 4-Runner TRD Sport, 2009 Matrix Sport
Hmm. I wonder if this might be the reason for the wind noise some people, including me, are reporting?
jankphil
Mine also does this, I don't really have any issues with wind noise though.
Did anyone report this to a dealer service department and if so, what did they say or do?
JD84081
Utah
Glad to see I’m not the only one with the window seal issue. I bought my 2025 Toyota 4Runner TRD Off-Road last week and noticed the problem yesterday.
2025 2026 4runner 6th gen Rear Door Window Seal - Looks like its incorrectly fitted both sides IMG_7349
I wonder if dealer usage of supra lock boxes causes this ?
2025 2026 4runner 6th gen Rear Door Window Seal - Looks like its incorrectly fitted both sides 1762552098402-21
EDIT: nope, no way, it comes like that from factory
mine has it, neighbors 4runner has it...
I got my 4R right of the delivery truck. No lockbox installed unless it was done during delivery. Its also the same issue both sides.
If anyone is bringing this to the dealer, please share dealer response. I am not schedule to go for an oils change for a couple of months.
mine is the same but its so slight of a dip in the grand scheme, it really doesnt cross my threshold to care. it probably could be pulled out slightly, but with the temps locally below 40F until next march, not much i can do about it currently (i have an unheated garage)
I checked mine again
and it isn't a mistake, it's by design they fit like that.
why ? no idea really.
