Suspension front lift to level my SR5
828findadventure
Tacoma & Tundra
Hi guys,
Has anyone upgraded their suspension on the 6th gen using Bilstein 5100s and used the adjustable perch to level the vehicle? I’m planning on doing a 2-inch front lift with the 5100s and keeping the rear stock height but still replacing it with Bilstein (like what’s shown on the Bilstein website / Performance level2 for reference). How was your ride experience on and off road?
Thank you
OK, here is a real answer. I had these on my 21 Tundra to level it out. I had the fronts set on the top perch to get the most lift. On the Tundra, it was about 2.5"; the rear shocks add no lift on the leaf spring rear suspension. Now the ride quality was the first thing I noticed on the winding hilly roads where I live, plus it canceled out any nose dive while braking, and that was with OEM front springs. I am not sure if the 5100s are available for the 6th gen 4runner yet, but that is definitely the most bang for the buck and a direction I would take if you want better ride quality, handling, and get a little lift at the same time. I currently have a Westcott lift on four corners to level the 4Runner with OE shocks since the 5100s weren't out yet. I plan on adding the 5100s later and still using the Westcott pucks.
828findadventure
Tacoma & Tundra
Not a fan of Bilstein after my last vehicle install. Have you considered the Old Man Emu MT64 ?
feel the ride would be much better than the Bilstein ?!
We did the Old Man Emu MT64 2135K and are extremely pleased with the results!
Also we do not believe in spacers so at least you're considering a suspension lift rather than spacers!
Come's ready to install 4Hrs we had ours Done !
I assume price.
romik
Romik
2025 Toyota 4runer
Thx for sharing.
You’re right, actually that was the best answer so far, and thank you for that. And yes, they are out. The screenshot I posted is from the Bilstein official website: you choose the brand, model, and exact trim, and it gives you options to choose from.
jayT
Banned
Banned
Banned
john
Louisiana
My friend,
From what your saying here I truly wish u to consider a rough country front spacer lift first. Give it a shot and go from there.
No alignment issues, cheap parts and very easy install.
exactly what i did with my 2025 4R SR 5 PT4WD and installed 285 70 R17 ...(go with the RC 1.5-2" Leveling Kit) i have absolutely no rubbing..the ride is decently smooth on-road, off-road is off-road..lol..
ThatSickRIp
TSR
VA
2026 4Runner SR5
OP, have you installed the 5100s yet? Looking to do the same to mine with just the fronts to get the 1.1-1.65" since after labor it will probably be the same cost as the WD collars
romik
Romik
2025 Toyota 4runer
ThatSickRIp
TSR
VA
2026 4Runner SR5
