rosnaby
alex
new jersey
4runner trd off road premium hybrid
The rear light has a bracket that can disconnect from the OEM light by undoing the plastic clips. Once removed, you can put the Meso hatch light on it and clip it back up on your headliner.
No drilling required on the rear as well.
Unsure which plastic clips you are talking about. Is it these little square ones on the housing next to oem light plug?
2025 2026 4runner 6th gen MESO Customs Switch-Back Interior Overhead Dome & Map Light Upgrade (White-Red Modes) IMG_4054
kburrito
2025 TRD Off Road Hybrid
Those clips are the ones you'll need to remove. Check out the video by Meso on how to remove it.
rosnaby
alex
new jersey
Ah dude thank you so much, i was trying to find this video and kept getting the map light one haha. Got it now thanks man
VB4Runner
Mitesh
VA
2025 TRD ORP
Just got these a couple days ago and installed them today. Overall install was easy. The dome light took about 5 minutes to replace and the map lights took about 15 minutes. Using a trim tool to assist in getting a firm grip on the overhead panel really helped get it out. I still did manage to break two of the bezel clips. For those who don’t want to drill, it’s definitely possible to route the wiring through existing holes. I didn’t drill any holes at all.
I am, however, having issues with the map lights not activating as expected. I’ve got mine set on “door” and the led module on the passenger side operates as expected, but the driver side doesn’t always come on when the door opens. I have to tap on the led module and then the light comes on.
When approaching the locked truck and using the key fob to unlock, once again, the passenger side comes on but the driver side does not.
I checked the connections several times and even took the whole thing back down and re-installed everything, but the same behavior persists. Any ideas?
Overall, the quality feels quite cheap for the price paid. But, they appear to be the only game in town for red LED replacements of the OEM interior lights
kburrito
I just finished installing my map lights just now. Im also curious as when i walk up to the car, none of the map lights turn on. Only the dome light. I would also be curious about this
As for door, both of mine turn on when door is open
VB4Runner
Mitesh
VA
2025 TRD ORP
For anyone else who may run into this issue, the workaround that I settled on was cutting a small piece of plastic to use as a shim between the led module and the surrounding trim. I stumbled upon that by noticing that if I used something to wedge the led module tightly against the trim, the lights always worked as expected when flipping between “off”, “door”, and “on”, as well as when locking/unlocking the truck via key fob.
Not much of a solution, but at least the lights now work as expected.
mush
Q
Houston, TX
2025 4Runner 2007 Tacoma
i know i saw somewhere that said the map lights will not come on until you open the door.
on mine both my dome and map lights come on when i come up to the car/unlock with the key fob. only thing about the map light on mine is that there is a slight delay(couple seconds) vs the dome light when i open the door to exit
i have a sr5 4x4 with 3rd row, toyota dash cam if any of that makes a difference
renz244
ME-SO Switch-Back Interior light upgrades w/ White-Red modes
Tacoma 4G map lights & Dome lights fit 100% in 4Runner
Install video here:
2025 2026 4runner 6th gen MESO Customs Switch-Back Interior Overhead Dome & Map Light Upgrade (White-Red Modes) IMG_4482
Quick question for you. Was this connector easy for you to insert during install?
As you can see in my photo, the connector on the Meso map light harness does not fully seat into the overhead console module. It stops short and never clicks or locks into place. I compared it directly to the OEM connector, and while it appears to be the same size and pin count, the OEM connector seats and clicks without issue.
I purchased the map lights listed for 2024+ Tacoma / 2025+ 4Runner on the Meso Customs website. I’ve confirmed the connector orientation is correct and even tested both directions to be safe. I’m hesitant to apply more force, as I don’t want to risk damaging the female connector on the vehicle side.
Just wanted to confirm whether this is expected and requires firm pressure, or if this may be a fitment issue with the harness.
BoxingAdvisor
Will
NJ
can you show a pic? Issue that I’m experiencing is that once I plug the stock plug in, my Map lights are now illuminated CONSTANT and cannot use the toggle to turn off in any way. I think the Mesa provided plug is BAD. Anyone experience a Constant ON issue?
renz244
I installed the Meso Customs map lights yesterday. The left light stayed on even after turning off the car and locking the doors. The other light worked fine, so I didn’t think it was an installation issue. I unplugged and plugged back in the lights, and they seem to be working now. I’m not sure why it fixed it, but it did. I was ready to email Meso Customs about this issue. Also, one of the circuit boards popped off when I took it out of the package. That was discouraging to see before installation. The parts feel cheap, but they seem to be working fine. I like the customization, but I’m not sure how long they’ll last.
VB4Runner
Mitesh
VA
2025 TRD ORP
Sure, see below. Have you disconnected/reconnected the power harness? Someone in another thread mentioned that they disconnected/reconnected the vehicle’s starter battery and that cleared up an issue for them.
I agree with @renz244 above – the quality of the product is not great.
2025 2026 4runner 6th gen MESO Customs Switch-Back Interior Overhead Dome & Map Light Upgrade (White-Red Modes) IMG_7191
AF VETERAN
Frank
Delaware
25 4Runner TRD ORP Hybrid Heritage Blue, 22 Jeep Overland, Black
Any pics with the light covers back on
