Mad Ghost
Justin
Wylie Texas
4Runner ORP and Avalon
Did you remove the factory lights?
If so Why? It does not require them to be removed!
Just curious!?
I installed and left the factory one sin since ......
no I left everything just added the Meso lights like the videos show
Van Solo
Van Solo
Van
Calgary / Canada
So Now I understand, Yes the SRS gives warning if powered on without being connected to the overhead console (Vehicle powered while overhead console detached)
Mad Ghost
Justin
Wylie Texas
I really like the red light, its bright but doesn't blind you, Will be perfect I think for passengers needing lights on road trips
kburrito
2025 TRD Off Road Hybrid
Are the white lights brighter than the stock OEM ones?
con5tant
4runner ORP Max
Meso lights seem to be too bright. I wish there was a diffuser or something, especially for the white lights. Red lights seem pretty bright too...
JackedAcctnt
Roger
Las Vegas
Thank you. I was able to install them today. I used a plastic pry tool to get the head unit console out. Ran into some issues with disconnecting the wires but was able to get it out with some patience and time
Van Solo
Van Solo
Van
Calgary / Canada
Great news
kburrito
Any advice you can give with removing the head unit? I have mine on order to come in soon
kburrito
It’s easy as pie, remove the plastic trim behind head unit underneath 4 screws
Thanks for the quick reply!
Anyone found a way to help reduce the bright white light?
JackedAcctnt
Roger
Las Vegas
I highly recommend using a plastic pry tool to make your life easier. You can find some on Amazon for like $5. I also pulled down where the blue clippings are in this post linked below.
To disconnect the wiring harness, there is a small clip you need to push down to wiggle out the connection. Be patient here because the clip (for me) was actually really stubborn. I came close to giving up since I did not want to cause any wiring damage by pulling on the wiring harness too hard.
Also be patient with removing the trim from the console, use a flat head screwdriver here to push in the clippings (similar to above). You will still need to pull with some force. Good luck.
(75) MESO Customs map lights / dome light installed | 2025+ 4Runner Forum (6th Gen) Community - 4Runner6G.com
rosnaby
alex
new jersey
So 2 questions because i got the same meso dome light
1) are u just leaving the meso lights without a frame over them? I think it looks alright but would love if they made a double button frame/light cap to dim the white leds a bit…
2) did you have to drill a hole in the dome light housing for the rear too? How did you get the meso light to stay up there?
JackedAcctnt
Roger
Las Vegas
The rear light has a bracket that can disconnect from the OEM light by undoing the plastic clips. Once removed, you can put the Meso hatch light on it and clip it back up on your headliner.
No drilling required on the rear as well.
