ctreble
irvine
Website
leapchiropractic.com
2025 4Runner Heritage Blue
So I just got the harness and wired my raptor lights to the other headlight. I think you could tap into the wire harness of the illuminated emblem due to the fact it uses the same fuse and is fine.
horbit
DFW
Very cool, show some pictures.
ctreble
irvine
Website
I just have the picture of the harness. I just removed the pre-existing wire and attached the Raptor light light harness to that point. Theoretically you could just attach the tap in to this harness for your raptor lights and it should work fine. If anything did happen the fuse would blow first.
2025 2026 4runner 6th gen OEM Illuminated Front Emblem: Dark Chrome w/ Light Up LED installed [+ part number / price] 59aba1c0-9939-4532-8255-9536e8757125
tanman
Tanvir
PA
26 4runner TRD Off Road Prm
Hi I am going to place an order on this. Do you know if this will work with a 2026 4Runner and whether or not it will block the front sensors??
ctreble
irvine
Website
I dont know if it works for the Full LED headlights in the upper trim models. But for Off road Premium and bellow it should. few options.
Illuminated Emblem + Raptor Lights = Tap Raptor lights into Emblem Harness.
Raptor Lights = Buy Harness PT413-89250-AC and connect harness to raptor light plug into headlight (or tap into fuse box) Harness comes with inline fuse.
Also noticed my Illuminated emblem and raptor lights dont turn on during the day time only at night or when i turning the lights all the way on.
If you want your raptor lights on all the time you would have to tap into another source like fuse box or something with constant power when car is running.
Mr. Wolfe
Greg
Pittsburgh
It can be pretty cool looking. My truck gets here soon and the dealership is installing a Heritage grille. If someone is interested in my light-up front grille, let me know. It will be for sale.
Mr. Wolfe
GatorFl
Wellington, FL
2020 4Runner Limited; 2026 Platinum on order
Does anybody know if this emblem can be retrofitted to a Platinum?
i have the oem PIO on my 25 4R and getting it on the wife's 26 4R coming in septmber.
just know, its not very bright and sunlight will make it invisible or dusk time transition is variable on seeing it.
Rellims
Rellims
Sean
ORP - Underground
Mine doesn't come on until it's dark. Tied into headlights.
did you manually tie them into the headlights?
i was pretty sure they are tied to parking lights, but been wrong before. i try not to go out at night.
but then again night time is after 930 pm where i am at currently.
Rellims
Rellims
Sean
ORP - Underground
Yeah the dongle it came with I plugged into the headlights.
mattfuria
Cincinnati, OH
2025 Black 4Runner Limited - 1999 Jeep Wrangler TJ
Same with Rellims, mine was a PIO on my limited. The logo only lights up when the headlights are on, when only the running/parking lights are on (IMHO it would be cooler if they turned on/off with the DRL and not just the headlights).
renz244
Thanks ! Going to work on it this weekend! That info will help alot.
Were you able to feed the wire correctly? If so, do you mind sending a pic or explaining it? I’m so confused on how to feed the wire and the pdf instructions in here won’t open for me
