A Cautionary Tale About Aftermarket Accessories—and an Expensive Unexpected Failure
CAMTuning
Cam
NM
2025 Tacoma TRD OffRoad
I wanted to share a recent situation because it is a good reminder that aftermarket accessories can sometimes cause damage far beyond the accessory itself. This is not meant to call out the customer or the manufacturer of the grille lights, and I have his permission to share the story. The goal is to show Tacoma and 4Runner owners how an accessory wiring issue can lead to damage you would never expect.
The chronology
This customer’s 4Runner had previously run correctly on the completely stock calibration, a COBB calibration, and my custom calibration. There were no performance concerns with any of them.
Then, during normal driving, the truck suddenly developed poor power, a misfire, and a check-engine light. The immediate problem turned out to be a blown ignition fuse in the underhood fuse box.
After the fuse was replaced, the engine ran normally again, but the truck was noticeably down on power. It felt like the turbo was no longer producing normal boost, and it eventually set a P0420 catalyst-efficiency code.
Because this happened after the vehicle had been tuned, the customer initially suspected the calibration. He was frustrated and understandably upset.
From his perspective, the timeline was simple: the truck was tuned, something failed, and now it felt weak and had an emissions code. However, it continued to feel weak on every calibration afterward, including the stock and COBB files. That was an important clue that the issue was mechanical or electrical rather than something within my calibration.
Instead of becoming defensive, I kept asking questions and gathering details. My goal was not simply to prove that the tune was not responsible. It was to understand what had happened and help get the customer’s truck working correctly again.
The detail that uncovered the root cause
After some additional questioning, I learned that the truck had an aftermarket grille with integrated lights. Those lights had been wired using an add-a-fuse installed in the ignition-fuse slot—the exact fuse that blew.
When that fuse opened, the interruption to the ignition system allowed unburned fuel to enter an already-hot catalytic converter. That fuel burned inside the catalyst and generated enough heat to melt the internal substrate.
Once the converter melted and became restricted, the truck felt down on power regardless of which calibration was installed. That also explained the P0420 code.
Nobody installing grille lights would normally expect them to contribute to a melted catalytic converter, but that is exactly why this situation is worth sharing.
The broader lesson
Modern Toyotas have a lot of systems tied together. A wiring problem does not always stay isolated to the lights, compressor, switch panel, stereo, or other accessory being installed.
An add-a-fuse in the wrong circuit, an overloaded circuit, a poor ground, a pinched wire, or an improperly wired relay can affect engine operation and damage something that seems completely unrelated.
This does not mean owners should avoid aftermarket lighting or other accessories. It just means the wiring and choice of power source matter. Critical ignition and engine-management circuits are not good places to add accessory loads.
The outcome
The customer has now ordered a high-flow catted downpipe to replace the damaged factory catalyst. Once it is installed, I will recalibrate the vehicle for the new hardware and review the data to make sure everything is operating correctly.
Most importantly, the customer now understands what happened and is satisfied with the path forward.
This situation required considerably more diagnostic support than would normally be expected from a remote tuner, especially because the underlying failure was unrelated to the calibration. However, I continued asking questions, reviewed the evidence, and helped identify the actual root cause.
My job is not just to send a calibration file. I want the vehicle to run correctly and the customer to be happy with the end result, even when the support goes well beyond the tune itself.
Hopefully, this saves another Tacoma or 4Runner owner from learning the same lesson the expensive way.
TRD_Alex
New York
2025 4Runner TRD Off Road Premium iForce Max, 2014 Jeep Wrangler JKU Willys
Good job. That is one expensive lesson. Don't buy half-assed products and do your due diligence.
got it, dont do tap a fuse to install lights that draw too much power from a tap a fuse
(and yes i know you dont pull all the light power from a fuse tap)
:ROFLMAO:
/s
SteveS
Steve
Puyallup, WA
Excellent information. Well written and a testament to your knowledge.
I see so many accessories that I question the design and built. I also question the self-installations by folk who do not have the background skills to do it right. I bet dealers see this all the time.
dealers love it when people do this. all they see is this walking in the door .... $$$$$
mfoga
r4unner
This is not the outcome I would expect but when people are trying to tap into this that and the other to make something look cool or do something unintended by mfg I am always thinking hope nothing goes wrong.
I had a plan for some lights and wanted to do something not even that crazy and 99.99% should be fine but there was some telling me what if this happens so I went the safe route and used the built in aux power. I didn’t get exactly what I had hoped for originally but it work and I know it’s much less open to causing a bigger issue.
There arent older cars where everything was Interconnected like things are now. Some of the old ways of doing things that worked for years may not be best practice anymore.
mars001
2003 4Runner SR5 4.7 V8
[QUOTE="CAMTuning, post: 137800, member:
[/QUOTE]
How did that fuse "get opened"?
CAMTuning
CAMTuning
Cam
NM
[/QUOTE]
"opened" = blown. Hard to say exactly based on the customer details, but with an add a fuse in that slot, it led to that fuse failing. It could have been a poor quality add a fuse, not fully inserted into the fuse slot, or it could have overloaded that slot. He discovered the fuse blown right away- another indication that he had suspected that fuse as the issue. It's not clear if he also noticed the lights not working (this happened at night) or if he just went to the last thing under the hood that had been changed.
calvincartier
Calvin
West Hollywood, CA
Awesome report. I’m a rookie here with all these electrical and mechanical stuff. And yes even me smart enough to know “DO NOT TAP THE FUSE” and or playing engineer with all these modern vehicle technologies unless you have the EXPERT knowledges, doing research and so on. I installed all my accessories. I took my time to do all the RDs, pro and con. I stay away from TAPPING FUSE method, knowing how much power I need for each accessories and how to manage all these accessories with OEM battery capacity and power supply.
FOR example on the hybrid system. You must be careful when installed any accessories. You have to disconnect the 12V battery system in the back cargo area first. Than in the front passenger side fuse box there are two poles. One for charging the 12V battery system if the car went dead and the other for pole is discharged max at 250A. I installed an AUX panel switch into this discharge pole, negative to the frame of the vehicle. All accessories will operated independently from the car electrical system. Switch panel will have 100A capacity. Anything more the switch panel will trigger the cut off power source. The switch panel acts as a safeguard for the car electrical system.
Ignore this basic step of disconnecting the 12V battery system in the back than the consequences will be “HYBRID SYSTEM FAILURE”. It took me over a month to do all these research and learning.
I can understand we are not mechanical or electrical engineers. But doing any thing outside your field of knowledges or understanding how thing works are beyond STUPIDITY.
unless its pretty much plug and play (diode dynamics hitch light kit), i no longer install mods myself. its either the professionals or the oem installs it (if aftermarket) when i can.
too old and dont have the time to do things DIY anymore outside of basic stuff. plus i dont mod as much as i used to.
good example is my old 84 cressida when i traveled from GA to ND for my first base. (btw i got 1800 miles on $100 borrowed, $20 for a bucket of KFC and rest in gas and slept in rest stops, god gas was cheap in the 80s, $0.92c, and yes i barely made it, it came close to $80 in gas)
installed piaa fogs and driving lights for night time driving. did the wiring and mounting (angle iron for mount strip)
but yeah i dont do these types of projects anymore. too much can go wrong with everything being tied into canbus and what not and error checks causing codes to get thrown for even being out of voltage specs
2025 2026 4runner 6th gen A Cautionary Tale About Aftermarket Accessories—and an Expensive Unexpected Failure 1984 Cressida-02 (Front)
CAMTuning
CAMTuning
Cam
NM
Cool old Cressida. I bet that thing is still out there somewhere running.
bakutheleo
2025 4Runner i-Force Max
Good writeup. I am a bit confused though--was the add-a-fuse installed incorrectly? If not it should have been fine--both circuits are protected separately. That is, unless the underlying fuse box connection itself is overloaded by both loads in the same slot.
CAMTuning
CAMTuning
Cam
NM
That's still an unknown. I considered the possibility that the entire add a fuse came out of the socket, but the customer says that it did not. I agree that it "should" have been fine. Since this customer is hundreds of miles away, I am sure there are some details that haven't been shared with me. Once the fuse was replaced the 4Runner ran again, although immediately down on power. There are a few unused slots in that box that would have been a better choice for adding a circuit, or there are the factory auxilary circuit options.
mars001
Adding 2 lights that are at least 55W each, 110W total, so that's adding 10A load to the original ignition which is 10A or 15A is not wise.
