BlueFinTunaGuy
Greg
Long Island, NY
2026 4Runner SR5
2025 2026 4runner 6th gen Silver SR5 (7 seater) Build- Bilstein 6112 / 6100, Westcott Designs rear pucks, Method 703 +35 offset, 285/75R17 BFG KO3 35436-3cfc0283a01aba8a7f4558119bbec841
2025 2026 4runner 6th gen Silver SR5 (7 seater) Build- Bilstein 6112 / 6100, Westcott Designs rear pucks, Method 703 +35 offset, 285/75R17 BFG KO3 35437-577b4b07abf24361db28eafd3fafa88
So after a month of having my 4Runner and reading about everyone's awesome builds. I planned out a build
Build
- 2026 SR5 (7 seater) in Cutting Edge
- Removed Air Dam
- Bilstein 6112's at circlip setting (#3) for a 2" lift in the front
- Bilstein 6100's in the rear
- Westcott Designs 1" rear pucks
- Matte Black Method 703s (17"x8.5" w/ 35mm offset)
- BFG All-Terrain KO3s 285/75R17
I have no rubbing, no trimming needed, no need to remove crash brackets. Everything just worked out perfectly, but oh is it close haha
Shout out to @Furrypanda1121, @romik, @Twisted, @TheMachine, and @dirtwheeler For your insight and/or inspiring builds.
The Bilstein 6112's at circlip setting (#3) for a 2" lift in the front paired with the 1" (~0.8") Westcott Designs rear coil spacers and a factory rake of ~1.6", retains a slight rake after lifting which makes it look super mean.
IMO the amount of rubber on the 285/75R17 fills out the wheel well perfectly and pairs really nicely with the (2" front + 2.4" final rear height).
2025 2026 4runner 6th gen Silver SR5 (7 seater) Build- Bilstein 6112 / 6100, Westcott Designs rear pucks, Method 703 +35 offset, 285/75R17 BFG KO3 IMG_4002
2025 2026 4runner 6th gen Silver SR5 (7 seater) Build- Bilstein 6112 / 6100, Westcott Designs rear pucks, Method 703 +35 offset, 285/75R17 BFG KO3 35439-b73b5ca514d961d47a33b27e109e8566
2025 2026 4runner 6th gen Silver SR5 (7 seater) Build- Bilstein 6112 / 6100, Westcott Designs rear pucks, Method 703 +35 offset, 285/75R17 BFG KO3 IMG_3972
2025 2026 4runner 6th gen Silver SR5 (7 seater) Build- Bilstein 6112 / 6100, Westcott Designs rear pucks, Method 703 +35 offset, 285/75R17 BFG KO3 IMG_3962
Bilstein 6112- installed
2025 2026 4runner 6th gen Silver SR5 (7 seater) Build- Bilstein 6112 / 6100, Westcott Designs rear pucks, Method 703 +35 offset, 285/75R17 BFG KO3 IMG_3961
Bilstein 6100- installed
2025 2026 4runner 6th gen Silver SR5 (7 seater) Build- Bilstein 6112 / 6100, Westcott Designs rear pucks, Method 703 +35 offset, 285/75R17 BFG KO3 IMG_3968
ysv85
Yessi
2026 Toyota 4Runner TRD ORP
Build
- Removed Air Dam
Can you add a picture of the 3rd row seats?
Joe Dirt
How was your alignment? I know 2 in is about the limit to lift before you need to replace the UCA. Thanks in advance
ds4r514
David
Montreal
I have been looking for the right setup. This looks like the perfect amount of lift and i like that there is still some front rake. Did you evaluate any rear shocks that would allow for the same lift as the puck?
mfoga
r4unner
Need new springs if you don't want the puck. The shocks are ready for a lift but if the springs are stock you won't get any lift
BlueFinTunaGuy
BlueFinTunaGuy
Greg
Long Island, NY
2026 4Runner SR5
I went in with the presumption that if I stayed under 2.5” of lift in the front then I would be able to recover back into alignment without needing to get aftermarket UCAs. Even though I’d be very tempted to get Bilstein UCAs for gen 6 4Runner when they come out with them.
The shop that did the installation did an alignment and said nothing about not being able to get in alignment.
BlueFinTunaGuy
BlueFinTunaGuy
Greg
Long Island, NY
2026 4Runner SR5
New rear coils typically lift the rear a minimum of 1.25” so in order to get a 1 inch lift in the rear, I believe rear pucks are what’s available. That’s just my understanding.
