ecornista
Nevada
camry
What did you guys end up doing with the spare tire? Did a 33” fit on the spare tire?
Skiddy
Seminole Florida
My setup is with a 2" Ready lift spacer kit. I still get a little rub when full lock in reverse but that is probably due to my offset. I do not recommend the 0 offset.
NICKK42
nick
los angeles
26 4runner
is this not possible to do on stock suspension? 17x8 plus 35 with 35x12.r17 tires
Cassie
Dallas, Oregon
2026 Toyota 4runner TRD Off-Road Premium
The wheels with that 0 Offset
Gorgeous! Do you get a lot of rub or other troubles with the 0 offset? I’m having a hard time finding the wheels I want in an offset any higher than 1mm. Ideally I’d like 18-25 but that’s been hard to find in the size I need.
jayT
Banned
Banned
Banned
john
Louisiana
Quick picture.
2024 Tacoma trd off road wheels powder coated all black with Goodyear territory mt in 285/70/17. No rub…not even close. There is PLENTY of room in the wheel well!
not shown in the picture is the land cruiser front skid plate with the air dam removed.
fox 2.0 going on sometime after the holidays. Thanks to All Dogs Offroad!
that RIG appears to be LOOKING FOR A DAMN TRAIL it can't RUN...Nice af!!!!
TheChad
chad
Las Vegas
2025 sr5 4runner
I also just put 285/70/r17 tires on my stock height and rim SR5. No rubbing at all and rides smooth. Let me know if anyone has questions.
I’m doing the same as you, wild peak on stock rims. Did you do a 0 offset or what?
watchbuzz
Buzz
East Coast, USA
'25 4runner SR5, '19 Golf R
Maan you’re telling me! I ended up with AT3s too and so far has only been a 1 mpg hit. Was 19.6 or so stock, sitting at 18.6 rn. Need to give it a few more weeks for the numbers to settle I reckon.
Does this account for the diameter change? I think the mpg is technically not correct on the SR5 oe setup because the tires are so small. The car actually needs 33’s to be correct.
charliemanse
DFW
2025 SR5 4X4
I’m sure a lot of factors go into how this is calculated. I changed a few things, so can’t nail down how much each change cost in mpg. Tires are still AT3s, but I have the Tundra/Sequoia TRD Pro wheels. They’re a bit heavier than stock I think. I have an 2.5” lift up front and an 3” in the back. Also took the air dam off. I drive a bit spiritedly too. So with all that, I’m sitting at 17.3 or so.
Shadow4r
Lorenz
6th gen 4Runner, 3rd gen Rav4
Definitely love how it look now. I'm planning to change stock tires too but i'm thinking 265/70R17 size to wrap the stock SR5 rim. At least now i'm sure nothing will rub.
Thank you for sharing your photos.
jayT
Banned
Banned
Banned
john
Louisiana
nice! i have 285 70 R17 on my SR5-no rubbing at all; even before i put a RC 1.5-2" Leveling Kit..cheers✌🏽
