Running board options
mfoga
r4unner
The thing about rock sliders is coming back from a camping trip with tent, full tank and not even all the things I might bring as far as stove ,extra water as it was not needed I am like 225lb from GVWR. Adding 50+ lbs for a better step doesn't seem logical when its not something I will likely need. I am still on stock wheels, tires suspension so I will likely be adding more weight there too.
FrozenTater
Scott
Honda Crv
I went with RCI 20 degree rock sliders with the top tread plate
2025 2026 4runner 6th gen Running board options IMG_1241
2025 2026 4runner 6th gen Running board options IMG_1242
jillmtmt
Jill
Elkins, WV
2025 Toyota 4Runner ORP
Do you find the 20 degree difficult to step up on? I was reading that if you needed to still be able to step up on them to reach the roof rack etc (I would because I'm short) that you should go with the 5 degree and not the 20. Thoughts? Thanks!
Brian Day
Brian
Empire MI
The other good thing about sliders is less door dings from someone who parks too close and opens their door to far .
surprisingly this doesnt work as well as you think.
most front doors are curved (top/bottom) so the middle will hit before the bottom will hit the sliders. rear doors mostly have a wheel well cutout so that is even worse for the slider to come into play.
your best bet is just to park out in the boonies and hope someone doesnt decide to come park next to you :ROFLMAO:
mfoga
r4unner
Anyone who has a ORP do you know know how much the stock running boards weighted?
FrozenTater
Scott
Honda Crv
I’m on the shorter side too 5’6 and a smaller foot. I don’t really find it hard to step up and reach, I also don’t carry on top that often. I store and sleep inside when I’m doing those trips. I have the top plate option for a little extra grip so maybe that helps the cause when I need it.
jillmtmt
Jill
Elkins, WV
Thanks! I decided to order the RCI 20 degree with the top plate....nowbI just have tonwait 3-6 weeks to get them 😭 (1 week down).
jbol74
Jerrod
2025 4runner trd off road
Just recently added Westcott Designs rock sliders. Well engineered with robust welds. Higher priced than options that are out there but I believe in the old adage; “Buy Once, Cry Once.”
They look great! Are they about the same width as the stock running boards? Also do you know if these sliders can be installed with the transfer case skid plate on?
Mother Goose
Tucson, AZ
2025 Toyota 4 Runner TRD Off Road Premium
I wouldn't see why they wouldn't. They mount to the same area/connection points as the OEM running boards did. To be sure, I'd reach out to Westcott, they will know 100%. They're about the same width as the OEM running boards but the kickouts do come out 3" to 4" out further
mfoga
r4unner
Wait sliders that mount to the same spot as the running boards? Don't the running boards mout to the body and the slider should mount to the frame. Unless you are replacing the trailhunter sliders then yes it would be same.
jbol74
Jerrod
Thanks! I’ll reach out to them.
if they are using the same mount points for the oem running boards, dont think 4 mount points is going to be enough strength to hold the vehicle weight on a slider (in my opinion)
usually sliders (best option) is to weld them to the frame for extra stength and the ability to hold a vehicle weight on them.
unless you have probably 8-12 bolts (maybe) to hold the sliders on the body/frame ???
Mother Goose
Tucson, AZ
I hate to lead anyone astray, but I had Westcott Designs install them and am not 100% sure how they were installed. The OEM running boards had 4 brackets with two bolts on each. Please contact Westcott Designs and get the latest and best info.
