Diode Dynamics Hitch Light (HitchMount LED Pod) - problem / install issue
juanelc
juan
2025 4runner
Got my @Diode Dynamics hitch light today and it sticks out of hitch. That makes it so that the light adapter doesn’t fully sit inside and it doesn’t compress the clips on the side. And so the light can easily be pulled out. I just want to secure it so no one can pull it out easily. Btw I do have a locking pin that does hold the adapter in place but not the actual light. Any help would be greatly appreciated
2025 2026 4runner 6th gen Diode Dynamics Hitch Light (HitchMount LED Pod) - problem / install issue IMG_7244
LuLu6G
Oluy
DMV
4R
Seats well on my other 2022 T4R. Maybe reach out to DD support. Probably not designed for these year model. Just a thought
juanelc
juan
2025 4runner
It does say on their website that it works for the 2025 2026 4runners. Im assuming they didn’t test the bracket properly and assumed it would work perfectly
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
I have it installed on a ‘25 and works fine. Not sure I am tracking the issue in your post. Can you explain more?
mcd_ovrlnd
SE PA
Mine is secured with a locking pin that runs completely through it.
Brian Day
Brian
Empire MI
Remove the clips and just use the locking pin .
the instructions tell you to snap off the tabs on the original housing if using a locking pin. you shouldnt need to use the adapter unless you are using a 2.5in receiver
the oem hitch is only a 2in size.
but if even using the adapter, if the lock pin is going thru the adapter and the original housing, it shouldnt pull out.
2025 2026 4runner 6th gen Diode Dynamics Hitch Light (HitchMount LED Pod) - problem / install issue 1776949826061-g2
i just went outside and tugged pretty hard on mine and even tried to push the clips that are exposed on the sides/top that are sticking out. the lockpin is holding it in place and it didnt even budge.
Compare your install against this install video where it looks completely flush.
https://www.4runner6g.com/forum/thr...chmount-reverse-4th-brake-light-install.3172/
Hopefully that helps.
if you use the oem holes for the lockpin it will stick out. in that link he is not using anything to hold the housing in place, they just pushed the light all the way in manually to get it flushed for the pics.
if you look at diode dynamics install video, they show it sticking out on a prado and a 2025 4runner.
zgreen
Zach
Hey JR. Just wanted to see how you like yours? I have been thinking about getting one, but haven't pulled the trigger yet. Thanks in advance!
i like it, but dont love it.
the beam pattern is way to narrow for my tastes. seems its more of a narrow pattern
/`\ instead of /```\ pattern
and after going thru a ND cold winter, i am not sure if maybe one/two of the leds inside is out or its just my imagination.
seems to be a 1-2 dead spots of no light coverage when looking at it now
but it is brighter than the oem lights and for the convenience of removal for installing a hitch, its a lot easier than other solutions.
zgreen
Zach
i light it, but dont love it.
Thanks for the feedback!
rocktheroad
Tampa
4Runner TRD ORP
Just to confirm, when you install this flush in a 6th gen 4Runner, you won’t be able to use your locking pin to keep it in place. I’m not too concerned about it slipping out without the pin, but I’m a bit worried about what to do when I need to tow - it’s a bit tricky to get it out.
