Heritage Grille Part Number: 53101-35170 and 53101-35160 (TRD Pro & Trailhunter Grill)
djohnson1017
Rochester, NY
2025 TRD OffRoad Premium
The letters only come in bronze (maybe silver too), but the good? news is the paint is worthless.
I got the matte black overlays and they look like ass with like a puffy shape, so I used alcohol to loosen the vhb to take them back off, and it dissolves the paint. It's just a thin single coat, no primer, no clear coat, nothing. Scratches if you look at it funny, mere denatured alcohol dissolves it. Like a worthless aliexpress toy instead of the exterior of a vehicle.
The bronze part is a seperate insert that is also only stuck on with vhb, So you could pry them out and clean the paint off easy and have plain black plastic, or paint the inserts some other black or color match the body etc.
(Here the T just happened to come off easy, but then the O stuck hard so I used alcohol and the scuffed part happened just from touching it, and I could see bronze dissolved in the alcohol run off, so the remaining paint is thinner and duller on the O. So the rest of the way I managed to get the hard way without using alcohol again.)
If you don't hate the way these black letters look, then the part number is above.
And these are just ordered for any of the toyotaparts websites listed in thr thread?
bkw777
Brian
NJ
25 SR5, 96 SR5
I used oempartsonline. The parts end up coming from a dealer but the site is like a front end for a bunch of different dealers. You just order parts and they come from whatever dealers have them. And 10% or more cheaper than the toyota site or any of my local dealers.
They aren't always the best for every single thing though. I got a few things from ebay instead. Some dealers list things there and some things can be a lot less. Once you know a part number you just check both.
bkw777
Brian
NJ
25 SR5, 96 SR5
I'll say one thing though, I said I didn't like the way the overlays look, but I just realized they have one big advantage. They don't have weak worthless paint. The main shell part is like silver polypropylene with black ink or paint that the alcohol didn't touch. The puffy part on the front is a resin dome sticker. The resin itself is black not a paint. Both of these will surely take a lot more weather and washing and highway blasting than that bronze paint.
Boobajoob
Calgary, AB, Canada
Escape
It doesn’t matter if it’s gas or hybrid for any of these right? My gas limited could take the TRD Pro top grill?
[EDIT] Doesn't matter at all. Only does if you're adding the bottom grill and need to move the camera
Japan
2025 4RUNNER TRD OFF-ROAD PREMIUM, Honda REBEL 250 SE
Are the "TOYOTA" letters on the Heritage grille removable? If so, does anyone know the OEM part number for just the letters? I’d like to buy a separate set to paint.
kobe24runner
Souther California
2026 4Runner SR5
Sorry to bring this thread up again. Do you think if I took a cloth with acetone, I would be able to just wipe off the bronze?
I also do not like the bulby look of the overlay
FlaFlaFloFly
Chicago, IL
2025 Off-Road Premium
Reviving this thread because I am curious how it’s going for those that wanted to remove the bronze. I want the matte grille, but don’t think the bronze would look good on my supersonic.
Has anyone had luck with aftermarket overlays, or just removing the bronze letters?
Maximus4R
Adam
Nashville
Good news on the letters is that they're just 3M'd on so you can remove and paint the existing letters if you don't want to buy the overlays. I've had both silver and white plastidipped (well technically DipYourCar) on mine and they worked out great.
mfoga
r4unner
If you go with the OEM upper and lower do you have to go third party to relocate the camper or does the OEM upper have the mount for the camera? I saw something with the rave off-road camera mount but seemed weird that a OEM grill would need that.
Has anyone got the cameras calibrated? What did that run?
SigPig94
D
MA
‘26 4Runner TRD Sport Premium
Updated with heritage grille part number and link to parts diagram schematic:
TRD PRO GRILLE PART NUMBER: 53101-35170
HERITAGE GRILLE PART NUMBER: 53101-35160
TRD Pro / Trailhunter grille part:
https://autoparts.toyota.com/products/product/grille-sub-assy-radiator-5310135150
Original post:
I want to get the TRD Pro heritage grille on my ORP and can't find any part numbers yet to order it. Anyone find it yet?
Hope you don’t mind a couple questions….I’m going crazy trying to confirm fit and part #s….I have a 2026 TRD Sport Premium and I just want the UPPER section of the heritage grill.
1) Will it fit my ‘26 Sport Premium? Part #?
2) What are available color options for the word “TOYOTA”
Thank you for any clarity/info!!
Dead Horse
Oklahoma
The OEM grill has the camera hole, but not a mount. I bought the $30 Rave camera mount and am going to relocate my factory camera up there by moving the wire harness.
From factory ORP to factory TH/Pro grill, it moves the camera about 14ish inches. You should be able to calibrate it yourself in the 'secret' menu on the stereo (there's a thread on it). Although, my factory ORP camera isn't calibrated worth a damn to start with...My front camera shows items at least a foot different from the side cameras in the 360 view...Pulling up to a curb with the cameras on makes the curb look like this ----____---- on the top-down view.
Gerardo
Gerardo
PNW
Yes it should fit
- Part 53101-35170, TRD Pro - gloss black with silver letters
- Part 53101-35160, Trailhunter - matte black with bronze letters
SigPig94
D
MA
Yes it should fit
Much appreciated!
Boobajoob
Calgary, AB, Canada
Escape
I installed the TRD Pro on my limited. Fit perfect. It’s not hard but you are taking the entire front assembly apart. Even if you’re only replacing the top.
bigbruse
robbie
va
2025 4runner
I just did mine this weekend and watching this video helped me complete the whole process in a few hours! Patience and a lot of clips
