OME MT64 lift kit installed (front set at 2.25") + Dobinsons C59-885V rear springs + Raceline Rogue 18X8.5 wheels + Goodyear 275/70/18 Ultra Terrain
3rdRunner
Bill
Yeah builds can become quite the rabbit hole…lol. I’m already “upgrading” the TH. Amsoil looks like a good bet. Did you do it yourself? Love your Taco- what suspension did you use?
Daronc
Daron
Santa Clarita, CA
Can you tell me if you clipped yours where the clip is in the picture, or one down from that where the arrow is
2025 2026 4runner 6th gen OME MT64 lift kit installed (front set at 2.25") + Dobinsons C59-885V rear springs + Raceline Rogue 18X8.5 wheels + Goodyear 275/70/18 Ultra Terrain IMG_0532
2012BAJA
2012BAJA
2012 LT-TX Baja Taco, 2022 TRD LBOR Taco, 2026 TRD ORP 4R
Yeah I did the Amsoil myself I do it when ever I think it needs it. Park your truck on a tarp since it does make a mess of your drive way if you don't lol... The Front is A total Chaos kit while the rear is JD fab SUA that's been modified a bit...
That is set at 2.5" one down will get you at 2.25". 2.5" should sit almost level with the Dobinson's I used so either one depending on your taste... Hope that helps
3rdRunner
Bill
Ok - that’s a good call about the tarp. What areas do you avoid? I’m assuming the exhaust. You said it takes a while to set up. Like 24 hours?
Armbender
Will
halifax
2025 4Runner ORP
Did you do the full front OME? UCAs? If you could post a link to the front setup that would be awesome.
I’m considering the same to eliminate the front rake (1.5”) but not cause squat when towing my light trailer
can you adjust the lift height yourself without removing anything?
2012BAJA
2012BAJA
I would say 24 hours on a hot day but it keeps setting up over time.
I am on stock UCA's this is kind of a one and done as you have to pull them apart to adjust them... The lowest these will go is 1.75" and they would probably be a rough ride as they would be right on the external bump stops...
Armbender
Will
halifax
2025 4Runner ORP
perfect. So just the front OME coilovers?
I thought for sure I read something about requiring UCAs for anything over 2” but I could be mistaken
Armbender
Will
halifax
2025 4Runner ORP
Did you run the stock rear shocks with the Dobinsons springs?
Daronc
Daron
Santa Clarita, CA
Can you tell me why it would ride rough, and what will be right on the external bump stop. The reason I'm asking is my plan is to set them on the second notch from the bottom.
2012BAJA
2012BAJA
Ran the MT64s in the rear as well
Maybe I drive crazy but even at 2.25" I feel that it contacts the front bump stops a bit early. Honestly If I had set them at 2.5" they would be about perfect in my opinion I just think 2.00" would really ride the bump stops...
Armbender
Will
halifax
2025 4Runner ORP
2012BAJA
2012BAJA
So the kit as follows:
OME front coilovers
https://overlandoutfitters.ca/colle...r-mt64-coilovers?_pos=11&_fid=9e2320746&_ss=c
OME rear shocks
https://overlandoutfitters.ca/colle...mt64-rear-shocks?_pos=12&_fid=9e2320746&_ss=c
Dobinsons Rear Springs
https://kraveautomotive.ca/collecti...ng-pair-c59-885v?_pos=39&_fid=715ad75dc&_ss=c
Did you need any sway bar spacers or brake line spacers seen in OMEs full MT64 suspension kit?
So far just the above I will probably order the sway bar and brake spacers. Oddly the ARBs part #s for these show they fit the Landcruiser only but I assume they are compatible being they are close to the same platform...
