OME MT64 lift kit installed (front set at 2.25") + Dobinsons C59-885V rear springs + Raceline Rogue 18X8.5 wheels + Goodyear 275/70/18 Ultra Terrain
3rdRunner
Bill
Yeah builds can become quite the rabbit hole…lol. I’m already “upgrading” the TH. Amsoil looks like a good bet. Did you do it yourself? Love your Taco- what suspension did you use?
Daronc
Daron
Santa Clarita, CA
2024 & 2025 Tacoma's & 2025 4Runner TRD Off-Road Premium
Can you tell me if you clipped yours where the clip is in the picture, or one down from that where the arrow is
2025 4runner 6th gen OME MT64 lift kit installed (front set at 2.25") + Dobinsons C59-885V rear springs + Raceline Rogue 18X8.5 wheels + Goodyear 275/70/18 Ultra Terrain IMG_0532
2012BAJA
2012BAJA
Eric
2012 LT-TX Baja Taco, 2022 TRD LBOR Taco, 2026 TRD ORP 4R
Yeah I did the Amsoil myself I do it when ever I think it needs it. Park your truck on a tarp since it does make a mess of your drive way if you don't lol... The Front is A total Chaos kit while the rear is JD fab SUA that's been modified a bit...
That is set at 2.5" one down will get you at 2.25". 2.5" should sit almost level with the Dobinson's I used so either one depending on your taste... Hope that helps
3rdRunner
Bill
Ok - that’s a good call about the tarp. What areas do you avoid? I’m assuming the exhaust. You said it takes a while to set up. Like 24 hours?
Armbender
Will
halifax
2025 4Runner ORP
Did you do the full front OME? UCAs? If you could post a link to the front setup that would be awesome.
I’m considering the same to eliminate the front rake (1.5”) but not cause squat when towing my light trailer
can you adjust the lift height yourself without removing anything?
