Yeah builds can become quite the rabbit hole…lol. I’m already “upgrading” the TH. Amsoil looks like a good bet. Did you do it yourself? Love your Taco- what suspension did you use?
Yeah I did the Amsoil myself I do it when ever I think it needs it. Park your truck on a tarp since it does make a mess of your drive way if you don't lol... The Front is A total Chaos kit while the rear is JD fab SUA that's been modified a bit...Yeah builds can become quite the rabbit hole…lol. I’m already “upgrading” the TH. Amsoil looks like a good bet. Did you do it yourself? Love your Taco- what suspension did you use?
Can you tell me if you clipped yours where the clip is in the picture, or one down from that where the arrow is
Ok - that’s a good call about the tarp. What areas do you avoid? I’m assuming the exhaust. You said it takes a while to set up. Like 24 hours?Yeah I did the Amsoil myself I do it when ever I think it needs it. Park your truck on a tarp since it does make a mess of your drive way if you don't lol... The Front is A total Chaos kit while the rear is JD fab SUA that's been modified a bit...
That is set at 2.5" one down will get you at 2.25". 2.5" should sit almost level with the Dobinson's I used so either one depending on your taste... Hope that helps
I would say 24 hours on a hot day but it keeps setting up over time.Ok - that’s a good call about the tarp. What areas do you avoid? I’m assuming the exhaust. You said it takes a while to set up. Like 24 hours?
I am on stock UCA's this is kind of a one and done as you have to pull them apart to adjust them... The lowest these will go is 1.75" and they would probably be a rough ride as they would be right on the external bump stops...Did you do the full front OME? UCAs? If you could post a link to the front setup that would be awesome.
I’m considering the same to eliminate the front rake (1.5”) but not cause squat when towing my light trailer
can you adjust the lift height yourself without removing anything?
perfect. So just the front OME coilovers? Shocks or springs?I would say 24 hours on a hot day but it keeps setting up over time.
