OME MT64 lift kit installed (front set at 2.25") + Dobinsons C59-885V rear springs + Raceline Rogue 18X8.5 wheels + Goodyear 275/70/18 Ultra Terrain
3rdRunner
Bill
Yeah builds can become quite the rabbit hole…lol. I’m already “upgrading” the TH. Amsoil looks like a good bet. Did you do it yourself? Love your Taco- what suspension did you use?
Daronc
Daron
Santa Clarita, CA
Can you tell me if you clipped yours where the clip is in the picture, or one down from that where the arrow is
2025 2026 4runner 6th gen OME MT64 lift kit installed (front set at 2.25") + Dobinsons C59-885V rear springs + Raceline Rogue 18X8.5 wheels + Goodyear 275/70/18 Ultra Terrain IMG_0532
2012BAJA
2012BAJA
2012 LT-TX Baja Taco, 2022 TRD LBOR Taco, 2026 TRD ORP 4R
Yeah I did the Amsoil myself I do it when ever I think it needs it. Park your truck on a tarp since it does make a mess of your drive way if you don't lol... The Front is A total Chaos kit while the rear is JD fab SUA that's been modified a bit...
That is set at 2.5" one down will get you at 2.25". 2.5" should sit almost level with the Dobinson's I used so either one depending on your taste... Hope that helps
3rdRunner
Bill
Ok - that’s a good call about the tarp. What areas do you avoid? I’m assuming the exhaust. You said it takes a while to set up. Like 24 hours?
Armbender
Will
halifax
2025 4Runner ORP
Did you do the full front OME? UCAs? If you could post a link to the front setup that would be awesome.
I’m considering the same to eliminate the front rake (1.5”) but not cause squat when towing my light trailer
can you adjust the lift height yourself without removing anything?
2012BAJA
2012BAJA
I would say 24 hours on a hot day but it keeps setting up over time.
I am on stock UCA's this is kind of a one and done as you have to pull them apart to adjust them... The lowest these will go is 1.75" and they would probably be a rough ride as they would be right on the external bump stops...
Armbender
Will
halifax
2025 4Runner ORP
perfect. So just the front OME coilovers?
I thought for sure I read something about requiring UCAs for anything over 2” but I could be mistaken
Armbender
Will
halifax
2025 4Runner ORP
Did you run the stock rear shocks with the Dobinsons springs?
Daronc
Daron
Santa Clarita, CA
Can you tell me why it would ride rough, and what will be right on the external bump stop. The reason I'm asking is my plan is to set them on the second notch from the bottom.
2012BAJA
2012BAJA
Ran the MT64s in the rear as well
Maybe I drive crazy but even at 2.25" I feel that it contacts the front bump stops a bit early. Honestly If I had set them at 2.5" they would be about perfect in my opinion I just think 2.00" would really ride the bump stops...
Armbender
Will
halifax
2025 4Runner ORP
2012BAJA
2012BAJA
So the kit as follows:
OME front coilovers
https://overlandoutfitters.ca/colle...r-mt64-coilovers?_pos=11&_fid=9e2320746&_ss=c
OME rear shocks
https://overlandoutfitters.ca/colle...mt64-rear-shocks?_pos=12&_fid=9e2320746&_ss=c
Dobinsons Rear Springs
https://kraveautomotive.ca/collecti...ng-pair-c59-885v?_pos=39&_fid=715ad75dc&_ss=c
Did you need any sway bar spacers or brake line spacers seen in OMEs full MT64 suspension kit?
So far just the above I will probably order the sway bar and brake spacers. Oddly the ARBs part #s for these show they fit the Landcruiser only but I assume they are compatible being they are close to the same platform...
zcmack
las vegas
Thanks for posting this, I am probably going to do the same lift as you with the Dobinsons springs as well, but I wanted to clarify one thing on the geometry:
Wouldn't a higher circlip setting (e.g., 2.5", nearer the top of the shock) cause more preload to the spring and create a rougher ride? You get a taller ride height because the spring is compressed tighter against the perch at rest. While lifting it higher gives the frame more physical clearance away from the bump stops, you sacrifice downward droop travel, and the preloaded spring requires a lot more initial force to move.
Not sure how crazy you mean when you say you drive crazy ;), but are you sure you're actually bottoming out against the physical rubber bump stop and not just feeling that harshness from increased spring preload and compression damping over sharp hits?
2012BAJA
2012BAJA
It's 100% hitting the bump stops :) !! I can see it on the shock shafts as they are totally clean after a spirited run... lol If i did this again I would still have set them 1 notch higher. I don't think 1/4" preload would be that much difference in ride quality if any considering where these shocks are designed to ride as in height...
This is my wife's Runner so she is more than happy with it's current set up but coming from my other truck I just feel like it could be a tad better.... lol
