ICE CAP WHITE Photos 4Runner 6th Gen (2025+)
bt75cj5
Bob
Washington
2025 Toyota 4runner, 2021 Jeep Gladiator
Project Trailhunter almost complete..
Added:
Westscott Designs Trailhunter 2.5" lift kit
35x11.50R17 Falken Wildpeak ATT4W Tires
KMC 17x8.5 Riot wheels with zero 0 offset.
I can say I'm loving the look even more now..
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 20260226_173942
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 30652-ab9616b84a2d6648b5646f48c0bb0e64
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 30646-15bc733e3c78a3c16871bb7bfd364400
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 30645-b15b70c9e660fa7d335ca8aa7bc893e7
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 30650-fbca4081649b85a9ed5df522cec29757
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 30649-13deaa97cc227b8ac40931fe4defa130
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 30648-e3a6454cd875f4528aae88af0bcad818
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 30647-4fa56673049f6595430ab6cfe939a6c8
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 30651-430fec23555397b86d794a38ae6d2e54
3rdRunner
Bill
Westcott Preload Collar Kit: Front + 2.5”, Rear + .75, level, preserves OEM capability.
Toyo AT3 C 285/75/17: More rubber when airing down, fits spare compartment w/ slight deflation, tucks nicely with articulation.
ADD Stealth Center Mount Bumper + Warn EVO 12S: Better protection, approach angle, recovery capabilities.
Performance:
OTT Stage 1 tune, AWE OFG 3” Cat Back Exhaust (AWE exhaust will probably be removed, serious resonance issues 1500-2000 RPM range, high gear (8), increased load demanded).
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 32181-bf0e54bea63f7bfb21379281988cb2d0
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 32182-e9248dcda1e2221807e7328ac97d03c
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) 32183-857e9f7410381c6e3752fb792cc2af2
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) IMG_0105
2025 2026 4runner 6th gen ICE CAP WHITE Photos 4Runner 6th Gen (2025+) IMG_0103
CUaaron25
Aaron
colorado
Quick trip out to test the new tires. TRD ORP, 1.5" RC level, 275/70R18 KO3s
you think those tires and wheels would have cleared without the RC kit? I’m considering the same set up for my SR5 with pro rims.
GiantR
Ryan
Utah
TRD ORP
Probably. I had no rubbing even with the OEM mudflaps. But these wheels are +45 offset, I think the Pros are +20
Beedeviled
Stacey
2026 4Runner Limited
Been hearing about the drone with the AWE exhaust system. Had great luck with Borla on my ‘21 2.3 turbo Ford Ranger, so will likely add the same s-type exhaust to my 4Runner. Your truck is looking great.
3rdRunner
Bill
Yeah - I swapped back to the OEM exhaust system this weekend. The noise (drone/resonance/rumble/cacophony -pick your adjective ) was just horrendous in the 1500-2000 rpm range in high gear when a load was demanded. If you listen closely to the stock system you’ll hear a little rumble in this range. The AWE OFG amplified this exponentially. I spoke to an exhaust shop and had them QA my install after I first put it on. They were big proponents of Magnaflow systems. Unfortunately they don’t make a bolt on system for Hybrids so I may try and cobble something together. I’ll check out Borla as well.
Beedeviled
Stacey
Do notice the extra exhaust noise in that range but the stock system manages it well. For upgrades, I’ve always preferred exhaust system focused companies (e.g. Corsa, Borla, Magnaflow, etc.) over companies that just happen to have systems as part of a greater catalog. Borla has the no drone s-type systems and I’ve never had an issue.
3rdRunner
Bill
Agree. AWE relies on the placement of ports rather than baffling material and IMO they just didn’t get this system right. My primary goal was reducing flow resistance (Poiseuille’s Law) with the 3” pipe but just not worth the noise. I’ll check Borla out.
katbax
Toronto
2026 4Runner TRD Off-Road Premium
Love your build - nice work.
On the AWE 0FG exhaust, I’m actually a huge fan of it. No drone for me and I find it sounds absolutely incredible. I have a ‘26 TRD ORP for reference.
3rdRunner
Bill
That’s good to hear. I had no issue with the overall sound except in the range I described. You’re running the Hybrid…correct.
katbax
Toronto
So far, no issues with that range.
Should have clarified that my ORP is straight gas (non-hybrid).
3rdRunner
Bill
Ok. Might be something with the shift points o.n the Hybrid. I’m glad it’s working out for you.!
Swiftarget
CC
British Columbia
Audi A3
Performance:
Interesting to see you can get the 285/75/17 AT3 into the spare.
AT3 are one of the tires I may choose and knowing you can get almost a 34” in the spare may tip that decision.
How much did you have to deflate it?
