Has anyone wired a Ham radio yet?
mightysnopants
chicago
I want to install a hard wired Ham Radio. I'm a total novice on electronics and have never hard wired a Ham into a vehicle so I'm looking for advice/expertise. Can I use the prewired Aux switch that is already connected to the battery? Or too much noise in the system and I should just run 15ga - 20ag wire to the battery? If its connect direct to the battery does anyone know where the best place in the firewall to go through from engine bay to inside the vehicle un her the dash? I made the switch over from a Jeep Wrangler (finally) to a 4Runner but Jeep makes it pretty easy to run wires because there are multiple entry points on both drivers and passenger side.
RogueWarrior65
Blair
I'm considering this myself. You should use 14 gauge wire at a minimum. I'm more interested in figuring out where to put the thing. On my Gen 1 4Runner, it lived under the passenger seat and I ran wire directly to the battery. There was an existing cable boot I could make use of. In my Trailhunter, the battery is in the rear but then I also have auxiliary device connections. There's a nifty cable clip that people use for a roof rack light bar that runs the cable up the side of the windshield. That's all well and good but I still don't know where to put the radio itself.
mightysnopants
mightysnopants
chicago
I guess I need to amend my question because I thought the 12v battery was in the engine bay but since I have a hybrid it seems to be in the back.
John2112
Austin Texas
Although I have a ham license I think gmrs is more useful. I'm going to let my license expire eventually. In the back country in Colorado gmrs will get you help quicker than ham radio will. Since cell phones connect to satellite now ham radio is obsolete. Set up a good 50 w gmrs radio in the 4Runner trail Hunter, works great.
bakutheleo
2025 4Runner i-Force Max
@John2112 Agreed, although why let your ham license expire? Doesn't cost much for another 10 years, then if you want it you do not need to test again.
Handoc
Greg
Pleasant Hill, CA
2025 4Runner ORP, Everest
BTW, you do need a License just for GMRS too... no test and it covers your entire family.
John2112
Austin Texas
I'll never need it again, got rid of all my equipment.
I do have a license for gmrs, although I noticed almost no one ever uses their call letters or follows the rules on it.
John2112
Austin Texas
Also, until recently I was using a satellite phone when in the backcountry which was more reliable for for emergencies. Now the cell phones connect to satellite and the gmrs for close-end communications works well.
mightysnopants
mightysnopants
chicago
So I went to fcc site submitted GMRS license application and there’s no way to pay the $35 fee. I signed into CORES system like it directed me to but no option for an individual to pay. I clicked every single link. It used to be easy. I paid other license fees easy. Not sure why it’s so hard now.
RenoBravo
Reno, NV
I’m with you trying to figure out where to mount the radio.
I have the Rago Molle center console panels installed, so I am thinking mounting it on the passenger side near where the center console grab handle is. I think that will probably work but I just want to make sure I am not overlooking the obvious, and find out later there is a better spot. I’m also concerned that there won’t be any cable path thru the firewall on the passenger side for the power and antenna runs.
fur_runner
Aaron
25 ORPH
To the OP's question, if you have the aux switches, one of the circuits (the white one) is a switched power that doesn't use one of the buttons. That's what I used for my radio
thomasJ2352
Tom
Northern Alabama
13' Frontier...soon to get new 4runner
when I get my new ORP in a couple months, I’m going to be transferring my HF radio system and my 2 m radio system from my frontier into the four Runner and that’s one of the challenges but enjoyable challenges that I have with the new rig, both of the radios will have removable heads that I’ll mount on or near the dash with the guts of the radios toward the back of the vehicle.
kzrman
Maine
2025 Trailhunter
I recently installed a Woxun KG-UV980P in my trailhunter.
I'm a ham radio operator and like the radio because it has a very wide frequency range.
It covers 28 - 29.7 MHz, 50 - 54 MHz, 108 - 136 MHz (AM), 144 - 148 MHz and 430 - 450 MHz.
Like others I was scratching my head trying to figure out where to put everything. I think though that I nailed it. The radio has a head that can be separated from the body. Better still, the microphone can act as a remote speaker and plugs in to the head. No more having to drag a extra wire back to the body. OK, so let's go through the installation. For the antenna i used a cowl mount bolted just inside the engine compartment. The antenna wire was run through the fire wall using one of the grommets already present. The radio head was mounted using double sided velcro to the top of the entertainment screen (I had previously attached a dashboard tray that also covers the top of the screen). The guts of the radio was mounted to the floor of the second hidden compartment, just behind the rear seats. Power was supplied by using one of the Toyota supplied power pig tails. The pig tail used uses the switched power source (Aux #5, 10 amp fuse, white pigtail).
I'm very happy with the outcome. It was more work than if one could put the radio under the seat, but in these vehicles there is already too much electronics already there.
2025 2026 4runner 6th gen Has anyone wired a Ham radio yet? 20260401_154913
2025 2026 4runner 6th gen Has anyone wired a Ham radio yet? 20260401_155047
2025 2026 4runner 6th gen Has anyone wired a Ham radio yet? 20260401_155258
RogueWarrior65
Blair
Where does the power wiring come out?
