RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension?
YanMik
Ian Escala
2025 TRD Offroad 4 Runner (Soon)
Question- there’s been back and forth on 33’s Specifically 285/70R17 AT4W tires rubbing and no rubs.
I plan to get RRW 17” RR2-S with -12 offset.
Kindly advise if this will rub on stock suspension?
I have the Off-road Non premium 2025 6th gen
YanMik
YanMik
Ian Escala
Gerardo
Gerardo
PNW
A -12 offset is very aggressive.
I have 265/70R18 tires (32.6”). 285/70R17 tires are 32.7”, basically the same size.
My wheels are the TRD Pro +20 offset and have about a 1” poke. There was no rubbing on stock suspension on a TRD Off-road Premium.
I can’t say for sure, but I bet a -12 offset will rub.
Might wanna try: https://www.willtheyfit.com/
YanMik
YanMik
Ian Escala
Thanks Gerardo, after more research I’m leaning towards 25mm offset
YanMik
YanMik
Ian Escala
Changing the title from -17mm to 25 mm
4Everest
Michigan
'04 Acura TSX, '25 4Runner
+25 should work just fine.
I'm not sure about your mudflaps; those are usually the first things you have to take off because they're so thick, but try it and see. There's a couple good aftermarket options now though.
BerkRunner
Berk
2025 4Runner SR5 4x4
I’m going through this process right now. I ordered some -12 offset wheels because I installed the Rough Country fender flares which are about 2” wider than SR5 stock fender flares and about .75~1” wider than TRD flares. The -12 offset looks like it will be perfectly flush with the new flares so rubbing on trails will probably be an issue with stock suspension. However, it may not be an issue for everyday driving. I’m not sure yet. I’ll be installing the Falken Wildpeak 275/65/r18’s (32.5”) this Saturday with stock suspension so I’ll let you know. After the install I’m going to an off road shop to see what they recommend. Either a 2” leveling kit or a 3”lift. We will see. I’ll include some pics of just the wheels mounted without the tires and update after the tires are installed. The last picture is looking up from the floor, you can barely see the flare hanging over.
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2611
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2612
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2615
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2758
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2759
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2613
YanMik
YanMik
Ian Escala
I salute you for posting this and being head on in this experiment! Can’t wait to see pics! Your wheels looks awesome, even better with Falkens!
BerkRunner
Berk
You bet man. Happy to help.
koukimonst3r
Vancouver
2025 Toyota 4Runner TRDORP
I have the same RC flares with 17x8.5 +25 wheels on 285/70/17 AT4W, the fronts are flush but seems like the rear I could get away easily with a 0 offset. Can't wait to see how the -12 fit!
BerkRunner
Berk
Alright, after waiting 2 months for the rims and a few day delay on the tires, finally got the new shoes. It looks amazing. I love it. There is the slightest rub against the front wheel well liner when the tire is fully turned and the car is reversing. It’s only rubbing the well liner though so no damage to the tire or wheel well. Although I could probably get away with no lift, I’ll probably install a 2” leveling kit for the front and that will resolve that rubbing plus a little more for the trails. No issues at all in the rear.
The tires and wheels look pretty flush with the fender flares. Maybe a tiny bit of poke but no more than 1/4”-1/2”.
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2808
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2809
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2807
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2806
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2810
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2801
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2802
Before:
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2798
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2793
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2794
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2797
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2792
2025 2026 4runner 6th gen RRW 17” 25mm Offset with 33” AT4W tires - rub on stock suspension? IMG_2795
