a_double
NV
5th & 6th Gen 4Runner
It should. Why can't you have the shop transfer stock TPMS sensors to new wheels? Save time on programming.
TPMS part number: 42607-02050
Thanks for the PN. Buying a new set for aftermarket wheels retains full functionality of the OEM set. Just in case.
Sensor programming is just a touch of a button followed by a drive. No big deal IMO.
porkyfly
Mid atlantic
2025 4runner TRD Offroad
anyone know if the trd pro wheels will fit trd OR without getting new tires?
SimpleSean
6th gen SR5, 100 series
What kind of lift do the ORM shocks use? Same control arms across all trims minus trail hunter? Rear springs the same? Heavily debating this
Dario
Portland, OR
Land Rover LR3
Your OR likely came with the 18s that are 7.5" wide and have a 45mm offset. Is this right? Tires should be 265/70R18. The TRD Pro wheels are 8.5" wide.
I'm not an expert but everything I've read says it should be fine. I also asked my kid who is an assistant manager at Discount Tire. He said "no problem" so I'm pretty sure there is no problem.
I checked a couple of calculators because I was sure the the wheel diameter would change. If it does, the change is marginal. It seem like the bigger difference is that the sidewall will flatten out rather than be rounded.
JGR
Gabe
Guess it is dealer dependent. One I chose doesnt have free shipping. Which one did you choose?
I chose the one nearby me in Austin, TX — Autonation Toyota
Dead Horse
Oklahoma
They'll be fine. I put factory OR tires on Trailhunter wheels, which are the same width and offset as the pro wheels. Been on my OR for quite a while now.
CUaaron25
Aaron
colorado
Recently upgraded my wife’s car from a 2010 Jeep Liberty to a 2025 4Runner! Could not be more excited. Curious if the TRD pro wheels will fit and run 285s on her SR5? I feel like they should but I’ve had it for about a week and haven’t had much time to look into it but would hit this deal tomorrow if so. The deal on those rims less than what I got my Tacoma rims for during Black Friday 2 years ago!
croome21
Cal
2025 Toyota 4runner SR5
Ah okay - looks like the one you posted is PTQ24-35230. I wonder what the difference is between that and PTQ24-34230.
This thread might help -https://www.4runner6g.com/forum/threads/toyota-trd-sunshade-sun-shade-part-number-ptq24-34230.4504/#post-82771
