Diode Dynamics D-Switch (installed)
NineOh4Runner
Gabe
Florida
Install below
Just picked up the D-switch from Diode Dynamics. I've seen there are mounts for Aux Beam and Cali Raised that make the switch panel look a little more seamless. Has anyone found a company that is making one for the D-switch?
This is the once from Cali Raised for reference.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) Screenshot 2025-09-12 at 6.01.07 PM
ngfilla94
Nathan
St. Peters, MO
2025 TRD Sport Premium
Twisted
5th Gen TRD -> 6th Gen TRDORP
I wanted to go with the D Switch to give it a try. I like some of the features but my measuring said the switch panel wouldn't fit in that spot very well or look very good if shoe horned in there. Not sure why they had to make the actual panel so large. I went with the SPOD BantamX in their mount and it looks factory. Everyone who looks inside asks what it is and if it was factory. That makes me happy.
NineOh4Runner
NineOh4Runner
Gabe
Florida
Yeah, the features got me. Went with a full diode dynamics light setup so it was an easy choice. I’ve been holding off on the install while waiting for my prinsu rack to ship hoping someone would drop a mount like the others. I’ll post the install once completed.
NineOh4Runner
NineOh4Runner
Gabe
Florida
Installed the D-Switch this week. Ended up mounting it on top of the fuse box next to the to the battery. The hardest part was getting the controller wire thru the firewall.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1377
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1378
Removed a lot of the trim in the drivers side floor to make it easier to get to the pass thru on the firewall.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1379
Find where the wire harness passes thru the firewall and pull back the sound deadening around it.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1380
Back side of the rubber boot for the wire harness
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1381
Other side in the engine bay. I've seen a lot of videos of people pulling the side back and fishing it thru that way. Don't be lazy, find something pointy and push it thru be careful not to hit the wire harness.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1382
Pro tip, un-bolt the horn to give yourself some more working space.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1383
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1384
Controller wire is thru.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1385
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1386
Attached some rubber wire hider from amazon to the back of this plastic to clean it up.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1388
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1389
Opted to flush mount it under the drivers side vent and not use the mount that came with it.
You can use the mount to trace out where you want it on a piece of tape before drilling holes.
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1390
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1391
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1393
2025 2026 4runner 6th gen Diode Dynamics D-Switch (installed) IMG_1394
Cleaned up the wire behind the dash and buttoned everything back up.
Still need to tie in the Ignition sense and dimmer sense wires to that harness but haven't gotten around to it yet.
If you know a good spot for those let me know before i have to go digging too much.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Has anyone installed the D-Switch in a hybrid 4Runner?
horbit
DFW
I just want to populate the blanks :(. Don't want a separate panel.
ngfilla94
Nathan
St. Peters, MO
@StickerFab sells OEM style switches that fit the blanks. I have a couple for my ditch lights and light bar.
ngfilla94
Nathan
St. Peters, MO
n1comedes
San Diego
Toyota 4Runner
I recently purchased the Dswitch panel and C2 2.0 chase lights to work with my Baja Designs rock lights on my roof rack. I want to be able to control the left pair and right pair rock lights and pair of chase lights separately as well have all of them turn on when i unlock the car on the keyfob and when i open the door to exit. Is there a way to be able to accomplish all that? Looking for guidance. Thank you in advance
