RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Awesome rig!
Tire size ?
How much lift ?
How does your ADO Fox Suspension compare to OEM ?
alldogsoffroad
alldogsoffroad
Chad
Lincoln, NE
2025 Toyota 4Runner SR5
This is from a photo shoot we did for Fox. The wheels and tires aren't what I normally run, but they're Method wheels +18 offset with Falken Wildpeak 295/70r18. This setup rubbed on the mudflaps.
I normally run factory Toyota wheels with Kenda RT 33x10.5r17, but like the look of the Methods so much that I may change wheels out for them in the future.
The kit is 2" lift and rides far better than OEM. The OEM SR5 suspension was really, really not great.
RunnerRocks
RedDog
Nature
Those wheels look awesome with black! (y)
With a 2" rear lift . . .
Were you able to achieve correct alignment with OEM UCA's ?
Did you adjust the rear Panhard (trac) bar ?
alldogsoffroad
alldogsoffroad
Chad
Lincoln, NE
Correct alignment and no need to adjust the panhard
JGR
Gabe
Sweet rig. What did you end up putting for the spare tire?
alldogsoffroad
alldogsoffroad
Chad
Lincoln, NE
how much did this setup affect highway mpg?
I get about 17mpg currently but my most recent measurement is with a full trade show loadout for Overland Expo SoCal which is where I am right now. I’ll update when I know mpg’s not loaded up with a canopy, etc strapped to the roof rack and creating wind resistance.
Chad:
Am I correct that this is the link to the coilovers? Fox 985 Coilovers from All Dogs
Does your vehicle have anything lifting the rear? (perhaps the spacer eraser coils? (Note that I cannot find the spacer eraser for G64R on alldogsoffroad.com - I believe a link is referenced in that other thread but thought you might like to know that you cannot get to the G64R spacer eraser on web site via either suspension kits or coil springs links from All Dogs - 4x4 - at least I couldn't - and not sure if its same one as listed for 4GTaco.)
BTW - I really like that the Fox setup all pre-assembled. Makes me think it would be a relatively easy DIY install. But a question about the coil springs they come with if you are willing to provide an assessment: how do the springs themselves compare to the OEM springs on different trims (e.g., SR5, TRD OR, PRO/TH)? and how do they compare to the springs in your spacer-eraser package?
Thanks!
alldogsoffroad
alldogsoffroad
Chad
Lincoln, NE
Chad:
Thanks!
Yessir. I am running our rear lift coils, which are the same as what is found in the spacer eraser. Shoot me a DM if you weren't able to find the link.
The Fox front coils are a little lighter in rate from what I recall, but Fox uses a little more preload to make up for it. I have been happy with the ride quality.
Sorry for the slow reply, I was on the road for Overland Expo Socal and just got back to Lincoln.
