LT285/70R18 - Falken or Nitto
jofe
Hi folks,
I have a dilemma related to choosing between these two tires:
  • LT285/70R18 Falken Wildpeaks AT4W - which is a C-load tire but HEAVY at 68 lbs per tire
  • LT285/70R18 Nitto Recon or Terra Grapplers - Which is an E-load tire but much lighter at 58.5 and 59.5 lbs per tire.
For me it comes down to what the more comfortable ride is, and (to a bit lesser extend but still good to know, which is better for MPG). I wanted to ask if anyone has any experience with both these tires and what they would recommend? Does the C-load on the Falkens offset their added weight or is it better to just go with one of the Nittos?
(PS: I know that Toyo's are also an option, but they're also E-loads and their weight is around the same as the Nitto's so it would lead to the same dillema.)
DannyvanDelft
Danny
Strongsville
2026 4Runner TRD ORP
I went 285/65/18 with the Falkens. They're SL rated, same diameter as the OEM 265/70/18 tires on my ORP, so I had to only buy 4 tires instead of 5, since I can use the spare if need be.
4NAUSET
NYC
2025 4Runner TRD PRO
I put on the toyos to avoid the weight of the Falkens - it was a rough ride and switched over to the Falkens and it’s MUCH smoother ride (gas mileage is brutal but lesser of two evils)
jofe
@4NAUSET Oh wow it was that big of a difference ride quality wise?
What is the MPG hit you took by switching to the Falkens you think?
And do you feel like you feel the extra weight of the Falkens at all? Like in the car's acceleration?
Joestac
jofe
@Joestac yeah I’ve considered the 275s too, but at that point it would make more sense to just get the SL load version of that from Nitto. Load is not that important for me. It’s mostly the size I really like. I’ve tried the 295 recon grapplers but they’re just a bit too big and rub at full turn even with a westcott precollar lift and removing the crash plates. I have a TRD ORP. I’m worried that the 275s will feel too small with the lift kit and too close to OEM.
Franco
Frank
San Clemente, CA
2025 4Runner TRD Off-Road
Falken is a good tire but heavy. I am using the Toyo AT3 with 3 peak snow rating and way less weight. I had the 34s and went to 35s. Not sure of the issues one of the other responses but the AT3s ride great and are money! Highly rated and light.
DMac307
Washington DC
2025 Toyota 4Runner TRD PRO
Thanks for the info.
Did you install these tires without any modifications? I'm looking for the largest tires for my TRD Pro without any modifications (no lifting or spacers). I also want to keep the mud guards. Unless I missed it somewhere, but I've read through other threads and it seems some type of mods are required for larger tires.
DannyvanDelft
Danny
Strongsville
No mods needed. These tires are wider than stock, but the circumference is the same, so no difference. And if you get a flat, you can use the OEM spare. We got hammered with snow here in NE Ohio and the Wildpeak AT4W are great in the snow. Really pleased with them.
2025 2026 4runner 6th gen LT285/70R18 - Falken or Nitto 20260110_122618
2025 2026 4runner 6th gen LT285/70R18 - Falken or Nitto 20260110_152035
Joestac
Damn, that is clean AF. Well done.
DMac307
Washington DC
Nice look! Thanks.
Looks good!
brodolf
Denver, CO
2025 Toyota 4runner TRD Off Road, 1961 Chevrolet Corvette
Just when I thought I was set on the SL 265/70r18 AT4W I come across this!
Looks great. Back to contemplating everything.
I was planning on getting a full sized spare. (Which I know is same diameter) And now not sure if the extra width would 1. be able to be mounted without mods 2. create clearance issues.
