ToyoTech808
ToyoTech808
Honolulu
25 4runner
Could you use the tires on the TRD Off Road (265/70R18) with the TRD Pro wheels?
Yes. The 4runner TRD off road wheels is the same size as the Pro wheels, just the offset is different.
DangItsDen
Hayden
Just posting here the TRD Pro wheels part numbers and what you need to install. You would need valve stem kits and center caps since wheels do not come with them.
The Tacoma valve stems are different part numbers but are same when visually looking at them. They work and are way cheaper than the 4runner part numbers.
Center caps from various wheels can fit depending on the look that you want. Most are also cheaper than the TRD Pro ones.
PT998-89210-F2 IS TRD Pro Caps
PT998-35240-F2 is caps from TRD off road
90942-A5010 is valve stem kits. NO SENSORS.
With Non TRD Pro caps.
Any chance you have some pics up close of those center caps on those wheels? I want to swap out the red circle pro ones but not sure which to choose. Thanks!
4cyl_runner
Rick
Arizona USA
Tacoma TRD OR, 2026 4Runner
Great info.
Is this the same wheel described here?
This is an upgrade option for a TRD OR I am looking at :
TRD 18-In. Wheel: Black (Includes 4 Wheels) These 18-in. alloy wheels with the TRD logo center cap throw down while styling up. .
Off-road race-inspired 18-in. x 8-in. cast aluminum wheel with 6 lug nut pattern .
45-mm. wheel offset widens the overall vehicle track width for more aggressive stance . Incorporates the proper weight, offset and brake clearance to ensure proper fit, finish and reliability Extensive ride, handling and strength tests ensure wheels meet TRD's high-quality standards.
$1,325.00
hussch85
Hussein
Cypress, CA
2025 4runner Limited Hybrid
bought a set of trd pro wheels w Falken wildpeak at3's for 1800 (facebook marketplace) , took my factory Limited 20" rims for 600 so paid 1200. fit perfectly no issues or mods , same sensors same everything else
for the record I thought i was experiencing some issues w turning radius but my *** self had it at H4L. H4F works fine
2025 2026 4runner 6th gen Part numbers for TRD PRO wheels, valve stem kit, center caps. Various center caps fit depending on the look you want. Image 2025-11-20 at 6.23.42 PM
ToyoTech808
ToyoTech808
Honolulu
25 4runner
Great info.
$1,325.00
The TRD Pro wheels and the TRD Optional wheels are different wheels. Offset and designs are different.
Great info.
$1,325.00
Per Toyo Tech, you are describing this wheel: Trd 18-In Flat Black Alloy Wheel - Toyota (PTR56-35242-F1) (MSRP $300) I'm guessing that the $1325 is for 5 wheels and slightly discounted? But you can probably do better by searching the part number on line. This wheel has +45 offset vs. OEM TRD OR wheel at +55 - very close.
I slightly prefer the look of the TRD PRO wheel and it its a bit cheaper (both MSRP and on-line) but you need to consider the impact of the +20 offset for the tires you want and the trim you have. Same advice: search part number on line: TRD PRO Flat Black 18" Wheel - Toyota (PT946-35240-2F); PRICE: $285 MSRP
AdFour
Washington
Question for those that changed to trd pro wheels. Can you reuse the tpms from your 18" wheels from Trd off-road wheels? And purchase new valve stems you linked above (without tpms).
Also any notice in difference with road noise or mpg?
ToyoTech808
ToyoTech808
Honolulu
25 4runner
Yes you can reuse the tpms sensors. Just need new stem kits cause once installed the stem is hard to remove without damaging it
kburrito
2025 TRD Off Road Hybrid
Thank you for this thread for the current 20% off at Toyota
kylec
Kyle
Iowa
Will TRD Pro wheels fit on a SR5? When I look on the Toyota parts website it says may not fit your vehicle.
The wheels will fit fine - same stud pattern. But offset is less: +20 (vs stock +55, I think). So need to be circumspect about tire size. Stock tire from TRD OR/PRO/TH will fit fine: 265/70/18. One size up will also PROBABLY fit without rub: 275/70/18. I promise you there will be some rub with that +20 offset on your SR5 if you go to 285/70/18 - my rub on TRD OR with that setup was relatively minor (crash plate - easy to delete; front felt; air dam screw tab) but might be worse with SR5 suspension. So just limit yourself to stock 265/70 (or 275/70 probably) and you should be good. Or plan to lift it 3" and get those 35s on:>)
abstraakt
Lakewood, CA
2025 TRD ORP Hybrid / Ice Cap
Can y'all confirm that these are the black stems? (same ones from the thread so I assume yes) 90942-A5010
Or, has anyone ever had any luck with bootleg TPMS sensors? lol
https://www.ebay.com/itm/257302523340
Yes, that’s the correct p/n for the stem. I purchased a set when I did a wheel swap for the TRD Pro rims.
2025 2026 4runner 6th gen Part numbers for TRD PRO wheels, valve stem kit, center caps. Various center caps fit depending on the look you want. IMG_8621
