Trailer Brake Controller Prewiring
s3lekta
M
ON, Canada
Hey all,
I'm trying to source a wiring harness for my Tekonsha P2 brake controller and it's proving to be a challenge here in Canada. According to an earlier post in this thread, the Tekonsha 304100 harness works for the 2025 4Runners, although the Tekonsha website still only indicates it's compatible with 2014-2023 model years (https://www.tekonsha.com/product/304100_trailer-brake-control-harness).
A local reputable hitch installer exclusively uses a different 304000 harness for all Toyota and Lexus and has had no issues, but hasn't yet installed on a 2025 4Runner. Tekonsha's site indicates the 304000 is only compatible with 2003-2013 model years (https://www.tekonsha.com/product/304000_trailer-brake-control-harness). The local shop has the 304000 in stock. Visually it looks exactly the same as the 304100.
I have a question in to Tekonsha directly on the compatibility but haven't heard back and it's been over a week. I just asked them again. I'm heading out camping in a couple weeks so anxiety is starting to kick in!
Curious if anyone in this forum has any insights into whether the 304000 harness also works? If I were to purchase and test it out, what's the worst that could happen? My thought is maybe a blown fuse...but I'm not an electrician so really am not sure. A "friend" said it could cause serious damage...so I thought I'd throw it out there to see if there's any intel in the community.
Thanks!
You could try the wireless option. Prodigy model or Curt bluetooth
JRunner
Jarvis
BC, Canada
2025 4Runner hybrid
Right...as a last resort. I'd only consider the Prodigy but it's like $600-700 CAD. I already have a P2 so a $35 harness is easier to stomach :)
rfdj
Kansas City
'25 SR5 4Runner 3-row
So the difference is the ring terminal/ additional ground wire. I did talk to Tekonsha before with the same question and the answer was that the system puts out more power. Next version they added the additional ground for protection
JRunner
Jarvis
BC, Canada
2025 4Runner hybrid
Thanks for that info. I looked at the pictures on the Tekonsha site again after reading your comment and sure enough the ground wire is visible only with the 304100...hiding in plain sight!
JRunner
Jarvis
BC, Canada
2025 4Runner hybrid
Just to put this to bed: I also spoke with Tekonsha directly today and they were super helpful. The 3041 harness also includes the addition of a diode to only send the signal to the controller. If you use a 3040 harness on a 2014 and newer 4Runner, it'll cause your ABS light to turn on. Tekonsha said it's not advised to use the 3040 on the newer 4Runners.
They couldn't officially verify that the 3041 will work on the 2025 model as they haven't tested it internally yet, but the tech was super confident it will work just fine (and we have a case noted in this thread where it works). The worst that could happen is it's wired differently and it shorts out the brake controller. No risk to the vehicle.
I found an online supplier and have ordered the 3041 harness.
JRunner
Jarvis
BC, Canada
2025 4Runner hybrid
Just installed my Tekonsha P2 Prodigy using my 304100 harness. I was originally gonna mount it higher up, below the Aux buttons (see first pic) but it impeded my knee getting in and out, so mounted it lower. Still easily reachable if a manual adjustment is required and more out of the way.
Pretty straightforward if anyone else is considering a similar setup.
Heading out Sunday on our first camping trip, just finished the miles for the break in period.
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_1733
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_1735
lmjeich
2025 4Runner Offroad
A tip. To get the switch blank out, that I did, I ended up pulling out the top of that part of the dash - need to pull the hard plastic piece off to the top and left as well to do that.
However I don't think that is necessary - having now got the blank out. I think it is possible to get a screwdriver (or two - one for each side) inside the blank and down the sides to the latch and pull them inwards. Here are pictures of the blank, inside and out, and where the latches are.
Just wrapped up installing the Redarc brake controller in my 2025 4Runner. I initially tried the method suggested here, but had no luck — the space behind the side panel is extremely tight. Accessing the switch blank by feel alone was nearly impossible; you can't see anything back there. After 20 minutes of fiddling with small screwdrivers, plastic trim tools, and a lot of patience, I gave up and decided to remove a few extra panels.
That made a huge difference. With better access, I was able to remove the blank cleanly, mount the main unit securely, and route the wiring with a tidy finish. This link was especially helpful in showing how to reach the back of the switch panel — definitely worth checking out if you're tackling the same install.
Boobajoob
Calgary, AB, Canada
Escape
Will confirm the gas limited without the aux package (only limited package available in Canada) does in fact have this connector.
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_1465
nate456789
Nate
florida
Takes about 30min to install. I just removed the lower switch cover and the brake controller plug is right there. There is a handy screw right there for the ground too.
2025 4Runner limited.
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9801
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9809
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9797
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9804
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9819
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9817
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9800
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9803
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9807
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9805
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9810
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9812
gvan1998
MD
Can you list all the parts needed for this intall? Im trying to add a brake controller to myO RP
nate456789
Nate
florida
  • Brake controller - EBRH-ACCV3-NA
  • Gen6 wire harness is a TPH-021
  • I think it was a 18” zip tie
  • Regular 3/8 long extension
  • 3/8 universal joint
  • 10mm socket
  • Plastic trim removal tool
Use the trim tool to gently pop the lower switch cover out from the top center to start.
above, someone shows how to pop the blank plate out. takes a little patience.
the white brake connector should be right there when you shine your light in.
connect the white ground from the harness wire to the screw I show using the extension and universal and 10mm.
plug the harness in to the connector and controller.
stuff the harness into the dash to the left.
run the zip tie through the bottom mounting holes with the controller oriented have the large connector facing down.
there is a metal brace that the ground wire is now connected to that I zip tied the controller to.
that should be the hard part covered. Snap the switch plate that comes with the controller into the blank hole of the switch panel. Plug the small connector into the switch.
If you want to use the smaller switch blank location I have another source for that. I haven’t received it yet to see how it fits.
2025 2026 4runner 6th gen Trailer Brake Controller Prewiring IMG_9830
gvan1998
MD
  • 10mm socket
Thank you!!!
Have you tested it out yet?
Boobajoob
Calgary, AB, Canada
Escape
  • 10mm socket
That smaller blank fits (TPSI-011) but be aware it’s for the elite and not the liberty. You’ll need to mess with it for the liberty remote to fit correctly
