Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels?
  • Thread starter Deleted member 3355
  • Start date
  • Watchers 16
alyssaagati
PA
2025 4runner orp
I can tell you with 100% certainty that what is showing above is 18x8.5 +20mm. I've got a set of 4 and K03s sitting in my garage waiting for 6th Gen to arrive next week. Center caps are in the bottom box, so no photos of that right now. I will try to snap a photo with natural light later with the center caps in place. These are flat black but look kind of shiny due to the flash.
PT 946-35240-2F
18x8.5 TRD PRO Spoke wheel / +20mm offset / 6 bolt - 139.7mm
20 degree snap-in TPMS (must be from 25 LC/4Runner - whole new system on these models)
Toyo Open Country AT3 P265/75/R18
LINK TO TOYOTA:
https://autoparts.toyota.com/products/product/alloy-wheel-pt946352402f
These are on national backorder through Toyota. The available date is TBD.
Last check there are 200 backorders for sets of 4 according to my parts person.
Anyone know if these rims are still on back order???
squawbum
Joe
Marin County
I just ordered 3 of them for my overland trailer. They had plenty of stock. It was Elmhurst Toyota. My dealer had an issue getting them as inly 2 were in stock at their distributor and he wasnt sure when a third could be got.
Here is a pic of my spare that came on my 2025 trd pro. And that is what I ordered. It has a 20 offset.
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? IMG_9906
alyssaagati
PA
2025 4runner orp
Thank you! Did you have to pay for shipping?
JW4RunnerCLE
Cleveland
I want to put these rims on my SR5 4Runner. What is the largest size tire I cold put on with stock suspension?
What is the largest size tire I could put on with a 2” Westccott lift ?
E.T.
Orlando area
2025 4Runner Off-Road
You can go as big as 33" tires (285/70/17) on the SR5 with stock suspension and factory wheels.
Like these SR5 --
https://www.4runner6g.com/forum/thr...-fit-on-stock-sr5-no-lift-no-rub-photos.2859/
https://www.4runner6g.com/forum/thr...-tires-possible-without-lift-or-rubbing.2837/
https://www.4runner6g.com/forum/thr...ak-285-70-17-at4w-33-33s-no-lift-no-rub.3032/
Joe Dirt
PT 946-35240-2F
LINK TO TOYOTA:
Hello, I know this is an Old Post, but I am getting ready to order a set of pro Wheels as well, and was wondering if they come with the center caps I am reading that they do but I would like to confirm with you and also how are you liking them with your new setup. Thanks in advance
aktalog
Brian
Portland, OR
Did you ever find out? I am also looking to order some soon.
I bought the TRD PRO wheels and they did NOT come with center caps.
I got two sets of caps from Nucar for <$6 each for one variant and ~$11 each for the other.
Very similar but one of the variants is a bit more convex and has a single circular ridge (I think this is what came on my TRD ORP - and I slightly prefer it to...) the other is a bit flatter and has a triple ridge. Looks like in the photo below you should be able to see that I have one of each on the two TRD PRO wheels (with Toyo tires). I'm not positive but I think the more convex one was slightly more - but still relatively inexpensive.
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? 20251028_060730
Joe Dirt
No they don't come with the TRD Pro center caps. But they're not very expensive as they are just little plastic caps.
Joe Dirt
PT 946-35240-2F
LINK TO TOYOTA:
I know this is an Old Post, but I just mounted my Pro Wheels on the other day with the factory 265 70 tires and it looks pretty good as it is. But I'm pretty sure if I go with a 275 70 18 the poke potentially is going to come out just a little more then what it is now. I do not have any type of lift or leveling kit installed yet. I do know that with that type of poke any type of puddle i go through will completely come up the side of my doors unless i have mud flaps or running boards which I don't.
Did you ever go with wider 275s and or any type of leveling kit or lift? Thanks in advance
Joe Dirt
Mike, I know this is an old post but I have the same Wheels as you with Factory tires. I noticed that these Pro Wheels push out a little further with a +20
Offset.
They look great the way they are but I know if I go with a 275 70 there might be more poke than I want to deal with because of water splash and debris..
do you have any pics of your 275 70 tires on your set up? I'm going to change out tires probably within the next year and want to go a size wider and a little taller like the 275 70s. Thanks in advance.
To be clear, I have two setups that I run now and neither of them are with 275s.
I run 285/70/18 Toyo A/TIIIs on the +45 offset TRD Flat Black Wheels and stock 265/70/18 Michelins on the +20 offset TRD PRO wheels. Photos below - for poke, imagine something a bit less than the 285s on +20.
I think the 275/70/18 on the TRD PRO would be a very good look and not TOO much poke (for my taste) and more importantly I do not think there would be any rub with stock suspension (but it likely would be close on both crash plate (behind front tires) and on rear fender with full upward articulation. Folks talk about concern of rock chips from the bigger poke but I've not experienced that (running boards and now rock sliders with step probably help some for me - but I'm not running mud guards currently (have some that I don't think I'm going to install).
stock 265/70/18 Michelins on the +20 offset TRD PRO wheels (sorry - no good shots of poke)
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? 20251115_102536-EDIT
285/70/18 Toyo A/TIIIs on the +20 offset TRD PRO wheels (Note: Second shot is from trip where I heard and felt the rear tires rub on the fender at full upward articulation - which is why I'm not running this setup anymore (I'm confident this would not happen with the slightly different PRO or Trailhunter suspensions and their wider fender flares.))
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? 20251012_124315
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? 20251018_131704
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? 20251018_093111
Current setup: 285/70/18 Toyo A/T III on TRD Flat Black (+45 offset):
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? 20260117_170020
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? 20260103_124054
2025 2026 4runner 6th gen Wheel Offset of 2025 TRD Pro 4Runner 6th gen factory 18" wheels? 20251018_130457
Joe Dirt
Thanks for those pics. I think the 275 70 will probably be the max that I'll go with the factory Pro Wheels with a +20 offset.
I don't think I would want any more poke with stock fender flares. Mostly too much stuff flying around.
