White smoke coming from tail pipe on a 2025 TRD Pro Hybrid
Bevssuv
Bruce
kenora ontairo canada
a 2020 Toyota Tundra trd pro crew max and a 2025 Toyota 4Runner TRDPor in mudbat
Smoking out of tailpipe when slowing down on a hybrid Trd pro is this normal
Mudbath
Royal
Mukilteo, WA
None
The obvious answer is no, but what you have typed is so ambiguous as to be useless.
Are you sure it is smoke? What color is it? What do you mean by "slowing down?" If you were driving on the highway and you let off the gas for a few seconds and then slowly got back on the gas, any oil smoke, or blow-by, would be indicative of worn piston rings, but that seems like a ridiculous diagnosis for an engine that can be, at most, 4 months old.
Bevssuv
Bevssuv
Bruce
Slowing down to stop at the stop sign I was behind my wife’s brand new 4Runner and it was white smoke coming from the tai pipe lots of white smoke
CrispyTacoLover
Not normal.
Bevssuv
Bevssuv
Bruce
It was white smoke lots of it when she was slow down to stop
EROtero
Columbus, OH
6G Trailhunter
This is typically a sign of oil leaking into the turbo. Not specific to 4Runners but any vehicle equipped with a turbocharger can have this happen. Usual suspects are turbo internal seals failing. Other potential causes can be coolant leaks and blown head gasket.
Tennessee USA
F350
Get it into a dealers service Dept ASAP. Sounds like Coolant in the combustion gasses to me. Head gasket? Turbo seals both previously mentioned. I thought if oil was getting in it would not be a white smoke but my knowledge is kinda dated.
4RunnerDude
Charlotte
2024 4Runner TRD Pro
Please let us know the status once you get the dealer diagnosis.
Bevssuv
Bevssuv
Bruce
Talked to the dealership to about my 4Runner and they probably just water it the exhaust burning off from being washed and nothing to be concerned about but to keep a eye on it
Bevssuv
Bevssuv
Bruce
No the dealership did before I picked it up brand new just picked it up only had 23km on
Mudbath
Royal
Mukilteo, WA
None
It should be very easy to differentiate between steam and smoke. Was this a onetime thing or is it ongoing? Most cars will show a little water out the exhaust on start-up, as condensation is usually present on engine start up.
Oil smoke will be blue and will smell like burning oil, coolant in the exhaust will smell sweet and there will be A LOT of white smoke.
I think you are worrying about nothing. Regardless, if it gets worse, your car is under warranty.
most likely water being converted to steam.
if the smoke is a hazy or off white its steam. if its bright white its smoke.
usually it will disappear after 5-10 mins of driving. happens after sitting over night predominately due to condensation over night.
also this more common on norhtern tier states than southern states, especially during the winter months.
Hacksaw
az
2025 4runner TRD-ORP
With a hybrid, is it possible the gas engine might not even start until you've driven some distance? Or does the gas engine always start when you push the start button?
On the white smoke, did it evaporate within a few seconds or did it linger in the air and was thick white smoke?
Anyway, check the oil dipstick to make sure the oil is clear to light honey color, and check the coolant to be sure it's transparent pink. If there's any sign of other colors or foaming or not transparent, could be a problem. But I presume the dealer checked these.
Bevssuv
Bevssuv
Bruce
Thanks for information
