Shawn_1121
Shawn
Hudson, NH
25 Sport Premium
having the stock aux switches was a game changer for the Bronco Community, made wiring up anything super simple. Looks like Toyota isnt putting this option in unless its the higher trims like TRD Pro / Trail Hunter. Yet in my area of Ma/NH I have yet to see anything besides those 2 trims have the aux switches optioned.
mars001
2003 4Runner SR5 4.7 V8
For those with non-hybrid, wish that it has 40A inside the cabin so that it can charge a power station quickly while driving (40A x 14V = 560W.)
Hacksaw
az
2025 4runner TRD-ORP
Just FYI, you need some seriously thick wire for 12V@40A (see this chart showing gauge vs distance of the run: https://dcthermal.com/wire-guidecharts/ ) For example, from the table, 8 gauge to go up to 4.5 feet. Thicker if longer than that.
mars001
If Toyota provides 40A, I assume they put in the proper gauge. That's why I wish they put in 40A for in-cabin instead of 10A. I'm not sure if there is an easy way to run thick gauge wires from the engine compartment to inside the cabin?
Rellims
Sean
ORP - Underground
Way easier than on the 3g Tacoma. The grommet through the firewall is easier to get to and much more flexible, at least on the non-hybrid version.
Hacksaw
az
No offense intended but it sounds like you're not evaluating this right. The table I linked to above (wire gauge vs max current at 12V vs distance) is universal. Brand of car doesn't change it.
Toyota only provides the pigtail and we know they minimize cost on everything so the gauge they provide in the very short pigtail for the 40A circuit is at best the minimum for that short distance. When you wire from the pigtail to some accessory, it's up to the owner to figure the distance of the route and appropriate gauge for the max current capacity of the circuit (i.e. not the accessory). Toyota would deny all liability for any damage cause by an owner not choosing the appropriate wire gauge for an accessory. It's not difficult to choose the right gauge, and the consequences of not following it could be bad. Hope this helped.
papadop88
Los Angeles
2025 4Runner TRD Pro
Does anyone have the right part numbers for the Toyota pigtail harnesses that are needed to plug into the aux wires in the engine compartment?
nickgd
Fl
6th Gen TRD Off-Road Hybrid
the part numbers for the pigtails are PT974-89251 and PT974-89252
Does anyone have any idea where all 4 connectors are? I can only find 3...
I found 2 in the engine by the front bumper, and one in the cabin up under the steering wheel
where is the 4th?
nickgd
Fl
The 4Runner hybrid has 2 plugs in the engine compartment and 1 under the dash. There is one more but I'm not sure where it is yet. You half to purchase the pigtails separately from Toyota.
any luck finding the 4th switch connector? I only found 3 as well....
nickgd
Fl
TurnerXC
Brad
Richmond, VA
I had 3 separate pigtails in boxes when I picked up my Pro. 1 pigtail for the "high" power switches and two for the "low" power switches
TurnerXC
Brad
Richmond, VA
PT974-89251
https://autoparts.toyotaoforlando.com/products/product/hi-aux-wire-harness-pt97489251
PT974-89252
https://autoparts.toyotaoforlando.com/products/product/low-aux-wire-harness-pt97489252
one is hi aux, the other is low aux.
the connector on the hi kit is larger...seems to fit the larger connect up near the front bumper
I've got two connection points together close to the front bumper. just eyeballing them right now it seems hard to tell which is which.
nickgd
Fl
Same. I think the larger of the two connectors is for aux 1 and the smaller is for aux 2 and the one in the cabin is for aux 3.
one of the pig tails I received has a larger connector than the other one. That's the other difference between the two part numbers...the connector size
2025 Toyota 4runner What are you using AUX switches for? IMG_0386
