Westcott Designs SP mount (Switch Pro Mount) install
dgorman
Dan
Evergreen Colorado
2025 4Runner TRD Premium
Like my other post, no instructions from Westcott. How does this go together?
2025 2026 4runner 6th gen Westcott Designs SP mount (Switch Pro Mount) install IMG_4859
2025 2026 4runner 6th gen Westcott Designs SP mount (Switch Pro Mount) install IMG_4858
dgorman
Dan
Evergreen Colorado
Ah found a FB video and saw it like this. Found some threaded inserts in back for the panel but what are the 2 visible ones for?
2025 2026 4runner 6th gen Westcott Designs SP mount (Switch Pro Mount) install IMG_4860
dgorman
Dan
Evergreen Colorado
A template and hardware to the panel piece would be nice too. Need to get calipers and measure all this out.
vready
Vince
Hood River, OR
2025 2026 4runner 6th gen Westcott Designs SP mount (Switch Pro Mount) install _W0A2272
See my post here:
https://www.4runner6g.com/forum/thr...-mounting-bracket-from-westcott-designs.7525/
You have to remove the plastic cover panel and measure for the location of the holes for the mounting screws (I agree, a template would have been nice...) but it wasn't that hard to figure out.
The SwitchPros keypad will press-fit perfectly into the billeted aluminum keypad mounting bracket, so no hardware is even required if you don't want to use it. Between the SwitchPros 9100 parts and the Westcott Designs keypad bracket, I had all the necessary hardware for my install.
I just needed to measure and drill the mounting screw holes, and then drill the 1/2" ⌀ hole to route the communication cable down to the footwell and forward through the firewall gasket.
If you de-pin the Molex connector on the Communication Cable (as described in the SwitchPros install guide) you can pull the cable through the nipple on the firewall gasket. Fits perfectly and provides a good seal.
Hope that helps!
dgorman
Dan
Evergreen Colorado
Yeah, I had reviewed your post several times. There’s no hardware to attach the mount to the trim. I’ve got everything prepped but need to go to Home Depot to find screws to screw the mount. My only point is a sheet, template and (2) more screws (other than the SP panel hardware) would have been detailed oriented from Westcott. :)
dgorman
Dan
Evergreen Colorado
Well, I got there in the end and ordered another end trim piece from the dealer for $65. I had to get my own 1/4”x20 1/2” in length hardware. I removed the stainless temp hardware and put in nice button Allen head. You can see it’s pressing against the clip but I think this is right. Notice the mistake holes.
2025 2026 4runner 6th gen Westcott Designs SP mount (Switch Pro Mount) install IMG_4889
2025 2026 4runner 6th gen Westcott Designs SP mount (Switch Pro Mount) install IMG_4890
2025 2026 4runner 6th gen Westcott Designs SP mount (Switch Pro Mount) install IMG_4897
2025 2026 4runner 6th gen Westcott Designs SP mount (Switch Pro Mount) install IMG_4895
