TRD Pro Performance Exhaust Drone
fpf2
Jeep
Anyone notice a significant and annoying drone from the TRD Pro performance exhaust? I've had mine for just over a week now and it can be pretty loud in the cabin. It's also pretty annoying when it changes from electric back to ICE. May look into having a local exhaust company make some improvements (and route the exhaust out the side as well).
ScoMay
Tennessee
2022 Ram 1500 Rebel
Are you aware that engine exhaust sounds are routed into the interior? Not sure why Toyota would decide to do that but that is a thing. And yes it is annoying - especially at highway speeds when you let off the accelerator.
I asked my dealer to turn it off when I picked up my Pro. They couldn’t figure out how.
Apparently the Carista app does allow you to shut it off. So it may be as simple as that for you. No need to rework your exhaust pipes/tip.
fpf2
Jeep
I did turn off the engine noise via Carista, but that is a very good point that I left out. It makes a difference on acceleration but not so much with the droning.
papadop88
Los Angeles
2025 4Runner TRD Pro
Gotcha. You can try to swap exhausts with someone near you that would like the TRD exhaust (Magnaflow I believe) for a regular one...
Hadelson
Hugo
Pennsylvania
24 Rav4, 24 RTR Spec3 Mustang
I've had that Experience with the TRD Exhaust on two older 4Runners with the 4.0 V6. What worked for me was to install a resonator in front of the TRD muffler. The Vibrant Ultra Quiet did the trick removing all drone and took the overall tone down a bit.
Ultra Quiet Resonators - Vibrant Performance
2025 2026 4runner 6th gen TRD Pro Performance Exhaust Drone 1759588707921-dm
outdoorCO
CO
2025 TRD PRO
Hadelson
Hugo
Pennsylvania
They come in several OD. I used the three-inch mounting in front of the muffler
toyota trd exhaust can be drony on sound, each person is different on how they hear it. on our 2016 tacoma, i had one installed after the fact and after a few months, it just got annoying (the wife and me both hated it in the end)
not much we could do, but after we traded in the 2016 tacoma for a 2018 tundra, we were never going that route again.
BillyG4Runner6G
Billy
Delaware
I have been reading about resonators, drone tubes and J-Pipes being fitted to your factory exhaust system to eliminate the drone sound. I am not looking to replace the factory exhaust with an aftermarket cat back system but rather lean towards modifying the current one.
I need to find a competent muffler shop that has experience with combating drone with precise calculations vs welding on a tube and hoping for the best. I am considering asking a shop to cut the factory short capped pipe at the rear of the muffler, add a 20“ to 30” stainless steele J pipe that turns and flows back towards the front of the vehicle and runs parallel to the muffler Inside of the frame rail. I would have them weld on the cap that was previously cut from the factory short pipe.
This could prove to be an economical modification that would keep the factory exhaust intact. Of course I would consult the installer for his expert opinion prior to any changes to be made.
I think I may pick up a 2” diameter flexible insulation tube from the hardware store so I can hold it up and bend it on the shape, direction and position I am thinking as a visual example.
Any thoughts about adding such a pipe and your thoughts about a better idea or spot to add a J pipe or drone tube? I am not sure adding a resonator will correct the drone? I know the other models have that muffler/ resonator at the rear past the rear axle. Is this Toyota‘s answer to eliminating drone from the exhaust?
2025 2026 4runner 6th gen TRD Pro Performance Exhaust Drone IMG_6885
2025 2026 4runner 6th gen TRD Pro Performance Exhaust Drone IMG_6886
2025 2026 4runner 6th gen TRD Pro Performance Exhaust Drone IMG_0207
Wagzilla
James
2025 4runner trd pro
I never hear you guys talk about change the tune because that will also change the drone.
tnokes410
Tom
Maryland
2025 TRD Pro
Got this put on a few weeks and I am very happy with the results.
