- Thread starter
- #1
Question
. if i dont install a TPMS on my winter tires, do i see alarm lights in my dash panel as the ECU wont detect any TPMS signal? Can i temporarily disable the TPMS? Thank you.
Cold Pressure Adjustments & Rules:
Air expands and contracts with temperature. A standard rule of thumb is that tire pressure changes by 1 PSI for every 10F.
If the temperature drops: Your tire pressure will decrease. You will need to add air so it remains at 33 PSI in the morning.
If the temperature rises: Your tire pressure will increase.
on i have my PKSB light on all the time since i turned it off completely. not really ideal to have that constantly being engaged during winters up here in ND.Thanks, makes sense.
Looks like I live with the light...
Wish you could turn them off completely, got enough warning alarms going off when offroading already.
I guess this is one way that the max of 4 registered sensors at any given time of the Limited could be seen as a "plus"! I have sensors in all 5 wheels, but the system does not seem to be able to support 5 pressures, unlike the PRO/Trailhunter/etc., despite having the big driver's display. There are only 4 displayed pressures.Thanks, makes sense.
You can turn most of them off but everytime you shut it down they reset to ON, and that gets old all day long when wheeling.on i have my PKSB light on all the time since i turned it off completely. not really ideal to have that constantly being engaged during winters up here in ND.
especially since it sits in the garage over night and i dont have a heated garage. usually the garage is about 10F warmer than the outside temp, which at -10/-20F you really cant tell the difference in that its fracking cold.
I don't KNOW this but I THINK the warning is thrown for PSI <30. I needed to get off the mountain quickly after an excursion a few weeks ago and aired up to 30 (from 17) to save some time. One of the tires read 29 PSI on the dash meter and it gave me a warning for just that tire. (IIRC)Because I have tires that don't fit in the wheel wheel I have to keep the spare in the cargo area. To make it as small as possible I knocked the air down to 20psi and tried recalibrating the pressure level in the TPMS settings, it confirms but then goes right back to showing low pressure for the spare. Am I missing something or is that just too low of a setting?
