Toyota Extended Warranty
as far as i know, toyota doesnt offer just an electronics warranty. that would be a 3rd party warranty.
the toyota vsa platinum covers the following and its a long list ....
ENGINE
All internally lubricated components and: Balance Shaft;
Camshaft; Crankshaft; Crankshaft Pulley; Cylinder Heads;
Engine Block; Engine Mounts; Engine Oil Reservoir;
Engine Oil Reservoir Pump; Equipment Drive Shaft;
Exhaust Manifolds; Flexplate; Flywheel; Idler Pulley; Intake
Manifold; Oil Pan; Oil Pressure Switch; Oil Pump; Oil
Sending Unit; Pistons; Seals and Gaskets; Supercharger;
Supercharger Intercooler; Tensioners; Timing Belt; Timing
Chain; Timing Cover; Timing Gears; Turbo Intercooler;
Turbo Wastegate; Turbocharger; Valve Covers; Water
Pump; Air Control Valve (ACV); Air Pump; Catalytic
Converter; Crankcase Ventilation Valve; Exhaust Gas
Recirculation Valve; Exhaust Manifold Heat Insulator;
Exhaust Pipe Gasket; Mixture Control Valve; Oil Cooler;
Oil Filter Bracket Subassembly; Pair Valve (Reed Valve);
Supercharger Bypass Valve; Supercharger Relay; Thermal
Vacuum Valve; Thermostatic Valve; Vacuum Switch;
Vacuum Switching Valve; Vacuum Transmitting Valve
MANUAL TRANSMISSION
Transfer Case Components (All internally lubricated
components) and: Clutch Master Cylinder; Clutch Release
Cylinder; Gears and Shafts; Hoses, Lines, and Tubes;
Seals and Gaskets; Shift Linkage and Cables; Transfer/
Transmission Case; Transmission Mounts;
Clutch Pedal Subassembly; Control Position Indicator Subassembly;
Master Cylinder Reservoir; Radial Ball Bearing (for Clutch
Release) and/or Clutch Fork; Shift Lever Boot and/or
Retainer; Shift Lever Knob
AUTOMATIC TRANSMISSION
components) and: Hoses, Lines, and Tubes; Seals and
Gaskets; Shift Linkage and Cables; Solenoids; Torque
Converter; Transfer/Transmission Case; Transmission
Mounts; Vacuum Modulator; Shift Lever Knob
AXLE ASSEMBLY
Front, Rear, 4WD and AWD: (All internally lubricated
components) and: 4x4 Actuators; Axles and Bearings;
Center Support Bearing; Constant Velocity Boot Band;
Constant Velocity Joints and Boots; Differential Carrier
Assembly; Drive Axle Housing; Drive Shaft; Hubs; Locking
Hubs; Seals and Gaskets; Thrust Washers; Universal Joints;
Viscous Coupling
SUSPENSION
(Front and Rear): Bushings/Bearings; Control Arm Shafts;
Electronic Suspension Actuator/Motor and Compressor;
Front and Rear Coil Springs; Front and Rear Stabilizer Bar;
Front Leading Arm; Front Spring Assembly; Radius Arm;
Spindle; Spindle Support; Steering Knuckle; Strut Rod;
Suspension Spring Shackles; Sway Bar Link; Torsion Bar
Spring; Upper and Lower Ball Joints; Upper and Lower
Control Arms; Upper Arm Shaft
STEERING
Gear Box internal components and: Bushings/Bearings;
Center Link; Horn Contact Ring; Hoses, Lines, and Tubes;
Idler Arm; Knuckle Stopper Cover; Pitman Arm; Power
Steering Pump; Power Steering Pump Pulley; Rack and
Pinion; Seals and Gaskets; Steering Column; Steering
Column Coupling; Steering Column Shaft; Steering
Dampener; Steering Gear Box and Pump Housings;
Tie Rod End
FUEL SYSTEM
Air Flow Meter; Carburetor; Charcoal Canister; Diesel
Fuel Injection Pump; Electric Fuel Pump; Electronic Fuel
Injection System; Fuel Filler Opening Lid Hinge Spring;
Fuel Injectors; Fuel Pressure Regulator; Fuel Pump; Fuel
Sending Unit; Fuel Sensors; Fuel Tank; Throttle Body
COOLING SYSTEM
Coolant Level Sensor/Tank; Cooling Fan Relay; Cooling
Fan Sensor; Engine Coolant Temperature Switch or Sensor
(at radiator); Engine Cooling Fan Motor; Engine Fan;
Engine Fan Clutch; Engine Fan Motor; Engine Fan Shroud;
Equipment Drive Pulley; Fan Bracket Subassembly;
Radiator; Seals and Gaskets; Thermostat
AIR CONDITIONING/HEATING
Air Conditioning Heater Box Assembly; Air Conditioning
Lines, and Tubes; Air Conditioning Pressure Switches;
Air Temperature Control Programmer; Blower Motor;
Blower Motor Resistor; Compressor; Compressor Clutch
Assembly; Compressor Pulley; Condenser; Condenser
Fan and Motor; Cooler Control Switch; Damper Servo;
Defroster Control Cable; Evaporator; Evaporator
Temperature Sensor; Expansion Valve; Heater Control
Head; Heater Control Valve; Heater Core; Idler Pulley;
Pressure Regulator Assembly; Receiver/Dryer; Schrader
Valve; Seals and Gaskets
BRAKES
Anti-Lock Braking/Traction Control Actuator, Pump
and Motor; Brake Booster; Brake Hoses, Lines, and
Tubes; Brake Pedal Subassembly; Disc Brake Calipers;
Load-Sensing Proportioning Valve; Master Cylinder;
Parking Brake Cable; Parking Brake Control Handle
Assembly; Parking Brake Lever Subassembly; Parking
Brake Pedal Subassembly; Proportioning Valve; Rear Brake
Backing Plate; Seals and Gaskets; Wheel Cylinders
HYBRID/ALTERNATIVE FUEL
Actuator Assembly Shift Control; Hybrid Vehicle
Generator Assembly; Hybrid Vehicle Motor Assembly;
Hybrid Vehicle Transaxle Assembly; Transmission
Input Damper Assembly; Battery Computer Assembly;
Battery Current Sensor; Boost Charging Inlet and
Plug-in Electronic Control Unit; Circuit Breaker Sensor;
Combination Meter Assembly; Combination Meter
Computer; Fuel Cell Water Pump; Fueling Receptacle;
Hybrid Vehicle Battery Blower Assembly; Hybrid Vehicle
Battery Blower Motor Control; Hybrid Vehicle Battery
Thermistor; Hybrid Vehicle Control Computer; Hydrogen
Pipes and Manifolds; Inverter Assembly with Converter;
Main Switch Assembly; Power Source Control Computer
Assembly; Power Steering Electronic Control Unit
Assembly; Power Steering Gear Assembly; Pressure
Sensors; Reducing Valve; Shift Lever Position Sensor;
Skid Control Computer Assembly; Steering Column
Assembly; Transmission Control Module
ELECTRICAL
Alternator; Automatic-Off Headlamp Sensor, Timer
and Switches; Automatic Shoulder Belt Motor and
Switches; Automatic Temperature Control Unit; Battery
to Ground Cable; Battery to Starter Cable; Blower
Motor; Blower Motor Resistor; Charge Warning Relay;
Clutch Starter Interlock Switch; Convertible Top Motor;
Cruise Control Actuator/Servo; Cruise Control Sensors
and Switches; Cruise Control Vacuum Motor; Defogger
Relay; Distributor; Door Control Relay; Engine Coolant
Temperature Gauge and Sending Unit; Engine Coolant
Temperature Receiver Gauge and Sending Unit; Engine
Cooling Fan Motor; Engine Tachometer; Fuel Gauge and
Sending Unit; Fuel Receiver Gauge and Sending Unit;
Guide Rail Limit Switch; Headlamp Washer; Headlight
Control Relay; Horn; Horn (for theft deterrent); Ignition
Coil; Ignition Switch Lock Cylinder and Key Set; Integration
Relay; Lamp Failure Indicator Sensor; Lock Cylinder Set;
Main Relay; Manually Operated Switches; Oil Pressure
Receiver Gauge and Sending Unit; Power Antenna Motor
and Cable; Power Door Lock Actuator; Power Mirror
Defogger; Power Mirror Motor; Power Seat Motors; Power
Sliding Door Motor; Power Window Motor/Regulator; Rear
Shock Absorber Control Actuator; Retractable Headlamp
Motor; Shoulder Belt Drive Motor; Smart Entry and Start
System Switch, Sensor and Electronic Control Unit; Spark
Plug Resistive Cord; Speedometer; Starter Motor; Starter
Solenoid; Stop Light Switch; Sunroof Cables; Sunroof
Motor; Taillight Control Relay; Turn Signal Flasher; Unlock
Warning Buzzer; Windshield Washer Pump; Windshield
Wiper Link Assembly; Wiper Control Relay; Wiper Motor;
Wiring Harnesses
COMPUTERS AND ELECTRONICS
Airbags; Airbag Sensors; Antenna Cord; Anti-Lock
Braking/Traction Control Computer and Sensors;
Automatic Shoulder Belt Computer; Body Control Module;
Circuit Opening Relay; Compact Disc (CD) Player; Cruise
Control Computer; Electronic Ignition Unit; Electronically
Controlled Transmission/Transfer Case Computer
and Sensors; Electronically Modulated Suspension Computer;
Engine Control Computer; Front Seat Airbag
Assembly; Graphic Equalizer; Knock Sensor; Navigation
System; Power Mirror Electronic Control Unit; Power Seat
Computer; Progressive Power Steering Computer; Radio
Tuner; Steering Sensor; Stereo Component Amplifier;
Sunroof Control Computer and Relay; Tape Player;
Tilt/Telescoping Steering Computer; Traction Control
Computer; Trip Computer; Variable Induction System;
Vehicle Security Computers and Sensor; Wiper Module
ADDITIONAL COMPONENTS
Accelerator Pedal and/or Bracket Subassembly;
Accelerator Pedal Rod Assembly; Back Door Lock
Assembly; Convertible Roof Hook; Door Handles; Door
Lock Cylinder; Front and Rear Door Lock Assembly; Front
Seat Belt; Glove Compartment Door Lock Cylinder; Glove
Compartment Door Latch Subassembly; Hinges; Hood
Lock Assembly; Hood Lock Control Cable Assembly;
Hood Support Assembly; Rear Seat Belt; Reclining Seat
Back Adjuster; Removable Roof Lock Handle; Seat Track
Assembly; Shoulder Belt Guide Rail Assembly; Sliding
Roof Drive Cable; Sliding Roof Guide Rail; Tail Gate Lock
Assembly; Tilt Roof Lock Handle Assembly
THESE ARE THE ITEMS NOT COVERED
Accessory Drive Belts; Batteries; Body Panels; Brake
Linings, Pads, and Shoes, Rotors and Drums; Bumpers;
Carpet; Chrome; Clutch Friction Disc and Pressure
Plate; Dash Cover and Pad; Door Fabric; Door Trim;
Filters; Fluids; Fuel Cell Air Compressor; Fuel Cell Boost
Converter; Fuel Cell Electronic Control Unit; Fuel Cell
Hydrogen Tanks; Fuel Cell Power Control Unit; Fuel Cell
Stack; Fuel Cell Vehicle Battery Pack; Glass (including
Windshields); Headliner; Heating Hoses, Lines, and Tubes;
Hoses; Hybrid Vehicle Battery Pack; Hybrid Vehicle Battery
Plug Assembly; Hybrid Vehicle Relay Assembly; Hybrid
Vehicle Supply Battery Assembly; Hydrogen Fueling
Electronic Control Unit; Interior and Exterior Trim and
Moldings (including but not limited to: Ashtrays, Covers,
Cup Holders, and Vents); Lamps, Light Assemblies/
Housings, and Light Bulbs; Nuts, Bolts, Clips, Retainers,
and Fasteners; Paint; Rust and Corrosion Damage; Seat
Covers; Sheet Metals; Shiny Metals; Spark Plugs; Structural
Framework and Welds; Tires; Vacuum Hoses, Lines, and
Tubes; Weather Stripping; Wheels and Rims; Windshield
Wiper Blades (rubber component); All interior and
exterior cloth, leather, and stitching including convertible
tops and/or vinyl tops including but not limited to: any
vibration, deterioration, discoloration, disfigurement,
warping, fading, staining, stretching, ripping, punctures,
tearing, and/or scratches
and before anyone reads that list above and wants to grumble about something in that list is not covered...know that a phone call to Toyota TMIS is what really decides. For example trim is not covered, and sun visor is considered trim. dealer would not fix my tacoma sun visor when it started to droop, 'cuz it's trim. called Toyota, asked about it, they said hang on a minute....ok yes we'll cover it because the hinge is failing. if anything else failed on the visor it wouldn't be covered.
old adage my dad use to say...
you can always ask, you may not get the answer you wanted but it doesnt hurt to ask
(only exception to the rule, when you are a teenager trying to get past curfew, dad would chop off 30 mins each time i asked, until i wised up and stop asking)
2025 Big Red
Ron
4 Runner 2025
This tread got me to review my extended warranty. I’ve purchased around 6 new vehicles over my life and never bought extended warranty. We were so excited to buy a 4Runner off the transport, I wasn’t as thorough as usual. The electrical warranty I mentioned above was the platinum. Ouch. So it does cover about all electrical. The only good thing is we got about 40% off for being a Costco member. So make sure you ask the finance guy about Costco discount. Now was he pulling my leg, who know?
4Everest
4Everest
Michigan
'04 Acura TSX, '25 4Runner
Thanks for the responses, everyone. This was my first new vehicle purchase in over 22 years, so I wasn't sure how to approach the warranty question.
I took delivery Monday (see profile pic!), and decided to pass on the warranty and use my 3/36k to shop around.
ConrodM
Conrod
2025 Toyota 4-Runner
Our first new one in 21 years- got us beat! Let us know what you find please (y)
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Do dealers offer military discount on extended warranties ?
Does all the money go to Toyota, or do dealers get a cut ?
vsa are a set price to toyota dealers only. dealers are middle man (so to speak) so they add their own markup.
some markup a little (and make money by volume sold) some a lot and gouge every customer
jayT
Banned
Banned
Banned
john
Louisiana
my first vehicle in 18 1/2 years..purchased a 2008 Toyo FJ Cruiser 4WD in the FALL of 2007..18 1/2 years later, purchased the 2025 4R w/PT4WD SR5... enjoy my fellow 4R lover!
Dougp1313
Doug
Oklahoma City (North), OK
2026 Toyota 4Runner
not a deal. you have up to 3/36 to decide on a Toyota Factory Warranty (VSA)
you do not need one now, or next week, or next year
so tell dealer to pound sand and find a much better price later
these guys are legit and sell legitimate Toyota VSA's
https://fd-warranty.com/
I got an 7 yr / 125K - $1375.00 2025 4runner
Dumb question, never bought an extended warranty. Regarding FD Warranty, Is it a one time upfront cost or an ongoing monthly fee?
one time cost
if you choose deductible then you pay that deductible later when <some> issue arises
I buy no deductible plans
NB-4Runner
Marc
New Brunswick, Canada
2026 4Runner
I’ve bought 10 vehicles, Only took extended warranty on the first, declined on others. I always decline extended warranties on everything. In the last 30+ years, I’ve paid less in out of warranty repairs than the sum of all those warranties.
That’s statistically true for most since the average repair cost amongst those that bought the extended warranty has to be less that the cost of the extended warranty for the company to make money.
It’s more like insurance, you pay up front hoping you don’t need it.
SparkyMMA
Leia
Hawaii
2009 Tacoma Prerunner
Note that unfortunately some states, like WA/OR/CA, don't allow the sale these products by any entity other than a dealer licensed in that state. So FD-Warranty can't sell to customers in that state, unless you have an out-of-state physical address at which you can actually receive mail.
This is awesome to know. BTW, would Hawaii qualify for the FD-Warranty? Thx
not sure how that would work since toyota in HI is served by servco, not directly by toyota.
you would have to contact them or talk with a local toyota dealer if they recognize toyota's vsa agreement.
SparkyMMA
Leia
Hawaii
Aloha Nodak,
See below from Troy/Factory Discount Warranty:
Unfortunately, we cannot issue policies on Hawaiian vehicles…I can only do it you’ve purchased your vehicle in one of the other 49 states and brought it over. The problem is that Servco (Toyota’s distributor in Hawaii) imports their vehicles directly from Toyota Japan rather than through Toyota Motor Sales, USA, so they’re not in the U.S. warranty database. They’re coded as vehicles built for the Japanese market.
Sorry I can’t help on this one!
Troy DietrichFactory Discount Warranty
