Standard cruise control issues
MTN Dew
Dave
DE
2008 fur-runner, 2022 4r TRD Pro, 2025 Trailhunter
So my adaptive cruise control works as it should. The standard cruise control does not want to work. Message say cruise control unavailable see owners manual. I cannot find a reason in the manual for it to not work. Anyone else experience this?
that's weird, dynamic needs many more functions to work and go green
standard should just work too.
does the ICON change from dynamic to standard at least ?
white = mode type, but cruise off
green =cruise on
dynamic icon (enabled)
2025 4runner 6th gen Standard cruise control issues 1772037483328-ea
standard icon (enabled)
2025 4runner 6th gen Standard cruise control issues 1772037539899-w5
MTN Dew
MTN Dew
Dave
DE
green =cruise on
Yes it change modes but it will not allow me to set speed.
to change between dynamic an constant cruise control you hit the toggle just below "C"
to initially set cc speed, you have to hit "C" button.
to increase to a higher set speed you have to push up on the toggle labeled "+ RES / -"
to set a lower cc speed you have to hit "C" again
if you want raise or lower the set cc speed in slow increments, you hit the "+RES/-" toggle
its completely counterintuitive from the old days and more complex than it needs to be
and a complete pita vs our 23 tundra
2025 4runner 6th gen Standard cruise control issues 1772052926210-
Wahoo
Alabama
2000 Land Cruiser
I assume you know this but as noted above you have to toggle to the “standard” cruise control option BEFORE pressing the cruise control button above the toggle switch. You cannot toggle to standard option after pressing the cruise control button. I see that error message if I try to do so. It is not intuitive.
