should since they have the same specs as all the toyota BOF vehicles
LX 21-25
GX 23-25
  • Center Bore / Hub Bore: 95.1 mm
  • Bolt Pattern (PCD): 6x139.7 (6x5.5)
  • Wheel Fasteners: Lug nuts
  • Thread Size: M14 x 1.5
  • Wheel Tightening Torque: 131 Nm
even the offsets are close
LX = 53-57 & 58-62
GX = 58-62
DangItsDen
Hayden
Looks so good! What tire is that? I have the Toyo Open Country AT3 in that same size and your sidewall looks different? Is that a load range C or E maybe?
SportRunner
David
DFW
2025 4Runner, 2025.5 Volvo XC90
Factory Lexus GX550 takeoffs fit great with zero modifications.
These look great!
Do you have a part number for the Toyota badged center caps? Or perhaps are these the stock SR5 caps?
Thanks!
slamkad
Dennis
Miamisburg, Ohio
Those are the factory SR5 center caps. I have changed the center caps. The part number for them is PT280-35221-5F
2025 2026 4runner 6th gen SR5 on Lexus GX550 Overtrail Wheels, 265/70/18 tires, Stock Suspension IMG_7875
QUOTE="SportRunner, post: 58475, member: 4890"]
These look great!
Thanks!
[/QUOTE]
nubbins_
Nice, this really completes the look. These the trailhunter center caps?
TrdProGirl84
2025 Toyota 4Runner TRD Pro
Here is my question. And it’s not a dig at you or anything. Why would you put wheels on a vehicle that are meant for different vehicle? ?
nubbins_
Did someone not tell you about TNGA-F wheel compatibility in general...?
Just don't go having an aneurysm when you find out that Bronco owners are putting Toyota wheels on their ride lol
4runner_lover
BC
4runner Limited
These wheels are looking great! I have a quick question: did you need to recalibrate your Toyota Safety Sense system after switching to a tire size with a larger overall diameter?
I assume your odometer readings are a bit off now. Have you had a chance to compare your speedometer reading with a GPS speed? If so, how much of a difference did you notice?
Also, is there any way to recalibrate the odometer or speedometer to account for the larger tires?
Thanks!
well that kinda defeats the purpose of aftermarket wheels in general, not just toyota making it simple logistics to standardize across all BoF vehicle to have the same wheel specs but different looks.
then you can swap a look between models trims or badges (toyota<>lexus) across years, refresh, or generations.
saves on having a part supplier design a new wheel look several times if you can just reuse a pattern from years ago or generations ago.
IRFAN0922
irfan
2026 Toyota 4Runner SR5
Many people have reported vibration through the gas pedal at highway speeds while using the stock tires. Did you experience any vibration before changing these tires? If yes, what was the status, and how was the ride quality?
The reason I am asking is because many SR5 owners, including myself, have reported that with the stock tires the ride feels stiff and we experience vibration—not necessarily shaking, but a noticeable vibration felt through the vehicle, especially at higher speeds.
slamkad
Dennis
Miamisburg, Ohio
You must be new here. I don’t take it as a dig, I take it as a question from someone who is a rookie when it comes to 4Runners.
Joestac
Sadly not new.
Just someone that likes to poison this forum with the awful opinion of if it isn't TRD Pro, then it just does not matter. Takes these digs at many people and has been called out on multiple occasions. Why I have them blocked. I only noticed it since you quoted.
Ignore and don't feed the trolls.
Those wheels look freaking great on your ride. Almost like Toyota and Lexus are related somehow. Odd.
slamkad
Dennis
Miamisburg, Ohio
Thank you, I appreciate it.
Sadly not new.
